OZVFR Posted February 8, 2022 Share Posted February 8, 2022 Does anyone know the thread type and size on the metal brake lines that run under the tank? There is a connection block on the front and the back where they change from metal line to trailer park rubber lines. The hard lines have a nut that screws into them, these are the ones I'm asking about. Link to comment Share on other sites More sharing options...
Xstoff Posted February 8, 2022 Share Posted February 8, 2022 Not exactly answering your question, but when I changed the brake lines, I removed everything, including the hard metal lines. Link to comment Share on other sites More sharing options...
OZVFR Posted February 8, 2022 Author Share Posted February 8, 2022 That's the problem, all the work and cost to replace something that doesn't need replacing. Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted February 8, 2022 Supporting Member Share Posted February 8, 2022 I used HEL lines when I did mine which used the existing hard lines. You could always give them a call as they're in Sandgate, Qld and were very helpful at the time with questions that I had. You might get the info you seek from them? Their number is at the bottom of this link. Good luck. https://au.helperformance.com/yamaha-mt-09-tracer-abs-2015-2016-flexible-oem-replacement-braided-brake-lines 2 Link to comment Share on other sites More sharing options...
OZVFR Posted February 8, 2022 Author Share Posted February 8, 2022 I’ve dealt with HEL before, but also found designing your own which I’ve done a few times now and ordering them is easy and cheaper than buying the kit. Go figure. 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 8, 2022 Supporting Member Share Posted February 8, 2022 15 hours ago, OZVFR said: Does anyone know the thread type and size on the metal brake lines that run under the tank? There is a connection block on the front and the back where they change from metal line to trailer park rubber lines. The hard lines have a nut that screws into them, these are the ones I'm asking about. 4 hours ago, Xstoff said: Not exactly answering your question, but when I changed the brake lines, I removed everything, including the hard metal lines. Yes, the replacement lines are designed to not have any splice or bridge points, one piece from the ABS pump to each of the end points. Cut out the old and throw them away. Once you realize the effort involved, you won’t want to bother piecing lines together, just replace the entire thing. 3 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted February 8, 2022 Supporting Member Share Posted February 8, 2022 58 minutes ago, betoney said: Cut out the old and throw them away. Once you realize the effort involved, you won’t want to bother piecing lines together, just replace the entire thing. I have to agree with betoney on this one having retained the solid links myself. It was a real PITA. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted February 8, 2022 Premium Member Share Posted February 8, 2022 Speigler has an excellent front and rear kit with the pivot clamp tool and color instructions. One piece lines are the ticket! 1 Link to comment Share on other sites More sharing options...
