ilanr1 Posted February 9, 2022 Share Posted February 9, 2022 Hi , i replaced my front shocks with Adreanni. The seller advice me to use Ohlins fork oil with 19 cst rate. What is the equivalence to a normal W rate for this 19cst value... Thanks Link to comment Share on other sites More sharing options...
ilanr1 Posted February 9, 2022 Author Share Posted February 9, 2022 From my search , every manufacturer is making it's own oil and then specify it. Motul 5W = 18 CST... What is the regular fork oil that we need to use for a stock fork ?. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted February 9, 2022 Premium Member Share Posted February 9, 2022 With my massaged fork dampening and heavier .95 Springs, I used 16 CST at 40C. Seems to work well. Link to comment Share on other sites More sharing options...
ilanr1 Posted February 9, 2022 Author Share Posted February 9, 2022 What is the brand and viscosity of it ? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted February 9, 2022 Premium Member Share Posted February 9, 2022 Torco RFF 5 wt. Link to comment Share on other sites More sharing options...
OZVFR Posted February 9, 2022 Share Posted February 9, 2022 If you look up “comparative fork oil viscosity” on the interweb, you will find lists of many brands and their weight so you can find one that you can buy locally. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 10, 2022 Supporting Member Share Posted February 10, 2022 6 hours ago, ilanr1 said: What is the regular fork oil that we need to use for a stock fork ?. The nice thing with changing fork oil is you can vary the viscosity to suit your needs. Since the compression damping is non-adjustable, you can alter the damping characteristics with a higher or lower viscosity. Lower viscosity is thinner and offers a faster fork travel, higher viscosity is thicker and offers a slower fork travel. The rebound damping is adjustable for any increase or decrease of viscosity you make. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
