LarryBud Posted April 22, 2023 Share Posted April 22, 2023 2015 FJ 09 I'm riding, the check engine light comes on and it powers down to an idle, I coast to a stop. I shut it off., restart with no light.. ride as normal and head for home. This repeats 3 more times. Each time after I restart, it rides as though nothing has happened. The final time, I ride 3 miles or so to home ( rides as new ) and park it. Not sure how to trouble shoot this. Suggestions? I was fortunate to only be a few miles out but now I need to figure it out. 1 Link to comment Share on other sites More sharing options...
robzilla Posted April 22, 2023 Share Posted April 22, 2023 Mileage on the FJ? Any previous maintenance done on it, ie, valves, air filter, etc? Has it been sitting for awhile prior to riding? Link to comment Share on other sites More sharing options...
LarryBud Posted April 22, 2023 Author Share Posted April 22, 2023 16k on the clock. I've been riding it all spring. Owned it for a couple of years and have just done oil / chain / tires. Previous owner took meticulous care of it. I'd have to look at each of the above but nothing done recently. I've not put many miles on it. It's my city bike. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 22, 2023 Supporting Member Share Posted April 22, 2023 If you got a CEL, what error code came up on the screen? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
LarryBud Posted April 22, 2023 Author Share Posted April 22, 2023 Just reviewed the maintenance schedule. All is in line with manual intervals ( air filter 23 months / 3K ago ). I did not see an error but it's possible I missed it. One possibility is the battery. I know this one is at least two years old. I keep it on trickle charger and it fires right up but I've had this mask a bad battery in the past. Link to comment Share on other sites More sharing options...
robzilla Posted April 22, 2023 Share Posted April 22, 2023 1 hour ago, LarryBud said: One possibility is the battery. I know this one is at least two years old. I keep it on trickle charger and it fires right up but I've had this mask a bad battery in the past. Probably a good idea to get it load tested. I've seen this too where an aging battery starts to do weird things even though it starts the bike up. Maybe check the connections are tight including the ground. Link to comment Share on other sites More sharing options...
skipperT Posted April 22, 2023 Share Posted April 22, 2023 Access DIAG mode, go to channel 61 and 62. Report what numbers are stored there, that will help us help you. -Skip Link to comment Share on other sites More sharing options...
LarryBud Posted April 26, 2023 Author Share Posted April 26, 2023 Just to close this one out. I replaced the battery and took it for a good spin. Looks like that was the problem. It had enough to start it every time but the bike did not like it. The battery was still the factory install. Not a bad run for a 2015 bike / battery. Thanks for all who replied and I hope I'm not claiming victory too soon. 4 1 Link to comment Share on other sites More sharing options...
larolco Posted April 26, 2023 Share Posted April 26, 2023 The battery was due to be replaced anyhow, so not money thrown away by any means. Link to comment Share on other sites More sharing options...
