NolaTracer Posted April 27, 2023 Share Posted April 27, 2023 On my second OEM battery within a couple of months. Won't hold a charge. I just started hearing a clicking noise under the front seat mounting bracket when I hit the start button. Any idea? Thanks! John 1 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted April 27, 2023 Supporting Member Share Posted April 27, 2023 Year, model, miles, any electrical farkles? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 27, 2023 Supporting Member Share Posted April 27, 2023 Same question as @Heli ATP have you added any electrical extras? Anything direct to the battery or on a non-switched circuit? The battery might be able to hold a charge just fine but something on the bike is possibly draining it. You could try removing the battery from the bike and charge it on your work bench and then let it sit and see if it drops the charge over time, that would tell you whether it is holding a charge or if something on the bike is draining it. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
bwringer Posted April 27, 2023 Share Posted April 27, 2023 Make sure the charging system is working, too. See what the voltage is with the bike running. 1 Red 2015 FJ-09, among other things. Co-Host of The Riding Obsession, a Sport-Touring Motorcycling Podcast Link to comment Share on other sites More sharing options...
NolaTracer Posted April 27, 2023 Author Share Posted April 27, 2023 17 hours ago, Heli ATP said: Year, model, miles, any electrical farkles? 2016 FJ09 bought with only 500 miles. Just passed 3k mark. No electrical add ons. I can jump it but will no start on its own. Link to comment Share on other sites More sharing options...
NolaTracer Posted April 27, 2023 Author Share Posted April 27, 2023 16 hours ago, betoney said: Same question as @Heli ATP have you added any electrical extras? Anything direct to the battery or on a non-switched circuit? The battery might be able to hold a charge just fine but something on the bike is possibly draining it. You could try removing the battery from the bike and charge it on your work bench and then let it sit and see if it drops the charge over time, that would tell you whether it is holding a charge or if something on the bike is draining it. No extras that would affect battery. I replaced an older battery but it what time. Put in a new battery. OEM from cycle gear and it would only hold a charge if I put a tender on it. I thought it was a bad battery so I swapped it out yesterday for a brand new one. Installed it but when I turn over. There's a clicking noise underneath the seat mount. I'm going to investigate and see what that might be Link to comment Share on other sites More sharing options...
NolaTracer Posted April 27, 2023 Author Share Posted April 27, 2023 5 hours ago, bwringer said: Make sure the charging system is working, too. See what the voltage is with the bike running. How can I check this? Link to comment Share on other sites More sharing options...
Lone Wolf Posted April 27, 2023 Share Posted April 27, 2023 1 hour ago, NolaTracer said: How can I check this? Do you have a voltmeter? Odd such low miles... cuz manifests like bad connection. https://www.revzilla.com/common-tread/how-to-test-a-motorcycle-battery 1980 Yamaha 850 Triple (sold). Too many bikes to list, FJ-09 is next on my list Link to comment Share on other sites More sharing options...
NolaTracer Posted April 27, 2023 Author Share Posted April 27, 2023 12 minutes ago, Lone Wolf said: Do you have a voltmeter? Odd such low miles... cuz manifests like bad connection. https://www.revzilla.com/common-tread/how-to-test-a-motorcycle-battery Thanks! Found video on YouTube testing electrical systems 2 Link to comment Share on other sites More sharing options...
skipperT Posted April 28, 2023 Share Posted April 28, 2023 18 hours ago, NolaTracer said: No extras that would affect battery. I replaced an older battery but it what time. Put in a new battery. OEM from cycle gear and it would only hold a charge if I put a tender on it. I thought it was a bad battery so I swapped it out yesterday for a brand new one. Installed it but when I turn over. There's a clicking noise underneath the seat mount. I'm going to investigate and see what that might be The clicking is probably coming from the starter solenoid. Make sure those 2 bolts are secure (usually 8mm bolt head - disconnect the BATT NEG first so you don’t arc out while tightening). Follow the positive batt lead from the battery to the starter solenoid if you can’t find it. -Skip 1 3 Link to comment Share on other sites More sharing options...
NolaTracer Posted April 28, 2023 Author Share Posted April 28, 2023 55 minutes ago, skipperT said: The clicking is probably coming from the starter solenoid. Make sure those 2 bolts are secure (usually 8mm bolt head - disconnect the BATT NEG first so you don’t arc out while tightening). Follow the positive batt lead from the battery to the starter solenoid if you can’t find it. -Skip Thanks! 1 Link to comment Share on other sites More sharing options...
NolaTracer Posted April 28, 2023 Author Share Posted April 28, 2023 Thanks @skipperT it was in fact the starter solenoid a.k.a. relay per Yamaha parts list. Got one in order. Thanks for the advice! John 1 1 Link to comment Share on other sites More sharing options...
Lone Wolf Posted April 28, 2023 Share Posted April 28, 2023 (edited) 29 minutes ago, NolaTracer said: ... it was in fact the starter solenoid a.k.a. relay per Yamaha parts list. Got one in order. Only 3,000 miles on the bike - how did you determine the part was bad? Let's say a battery has low voltage (below 12) or is near end of life and just doesn't have the balls to crank the engine. In that case it would be "normal" to hear a click from solenoid, because it is doing it's job of making a connection for the big heavy wire circuit to deliver maximum amps to the starter from the battery, after receiving a signal from the comparatively small wires coming from the starter switch. Same thing can happen if one of the connections is not tight and clean. It is common on motorcycles and cars to hear a "click" when you try to start it up but it doesn't crank. When everything is working as it should you don't hear that click because the sound of cranking and running engine are more prominent. 2 hours ago, skipperT said: The clicking is probably coming from the starter solenoid. Make sure those 2 bolts are secure... Exactly. I would suspect a loose connection (after trying multiple batteries). Doesn't mean to replace the solenoid unless it is bad, which would be rare on low mile vehicle. Edited April 28, 2023 by Lone Wolf 1 1980 Yamaha 850 Triple (sold). Too many bikes to list, FJ-09 is next on my list Link to comment Share on other sites More sharing options...
NolaTracer Posted April 28, 2023 Author Share Posted April 28, 2023 32 minutes ago, Lone Wolf said: Only 3,000 miles on the bike - how did you determine the part was bad? Let's say a battery has low voltage (below 12) or is near end of life and just doesn't have the balls to crank the engine. In that case it would be "normal" to hear a click from solenoid, because it is doing it's job of making a connection for the big heavy wire circuit to deliver maximum amps to the starter from the battery, after receiving a signal from the comparatively small wires coming from the starter switch. Same thing can happen if one of the connections is not tight and clean. It is common on motorcycles and cars to hear a "click" when you try to start it up but it doesn't crank. When everything is working as it should you don't hear that click because the sound of cranking and running engine are more prominent. Exactly. I would suspect a loose connection (after trying multiple batteries). Doesn't mean to replace the solenoid unless it is bad, which would be rare on low mile vehicle. Brand new battery, all connections are like new clean. Just watched a video showing the same exact problem. The solution is a new starter relay. If it's not I'm only out 34 bucks. all voltages check out Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 28, 2023 Supporting Member Share Posted April 28, 2023 2 hours ago, NolaTracer said: Brand new battery, all connections are like new clean. all voltages check out So the battery is holding a charge correctly? 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
