Supporting Member betoney Posted July 24, 2023 Supporting Member Share Posted July 24, 2023 6 hours ago, Ride365 said: I just had to rotate my bar ever so slightly back as was "barely" making contact with my hand guards at full lock, no more clearance issue.......of course I have the sport screen. I think this could be the solution, anything could affect the screen clearance, bars rotated forward a bit, bar risers in the forward position, aftermarket up and back bar risers, aftermarket hand guards or hand guard position. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Jayzonk Posted July 24, 2023 Author Share Posted July 24, 2023 Runnijg everything stock. I could rotate the bars back but I'd have to adjust everything on the bars back into position plus find suitable hardware bolts for the handlebar. The Yamaha dealer can likely get me the proper grade of hardware. Link to comment Share on other sites More sharing options...
Suzukiguy Posted July 24, 2023 Share Posted July 24, 2023 Loosen the handlebars, rotate them to where they will clear, tighten the handlebars back up. No need to get new bolts, IMO. Then go ride! 2 2020 Tracer 900GT /1978 Suzuki GS750E /1978 Suzuki GS1000 /1982 Suzuki GS1100E /1999 Honda GL1500SE Link to comment Share on other sites More sharing options...
Heavy Posted July 24, 2023 Share Posted July 24, 2023 3 hours ago, Jayzonk said: Re: the screen. You're not using it anymore? And you cut it down from the normal height? Yes, and yes. There is never enough time or money to do it right the first time. Link to comment Share on other sites More sharing options...
RD52 Posted August 29, 2023 Share Posted August 29, 2023 Many aftermarket parts require a bit of tweaking to fit and/or function correctly. Lots of reasons for that, some out of control of the manufacturer. In your shoes I'd either rotate the bars back a skosh, dremel the edge, or just live with the very light contact at full lock. Probably the latter. If you do loosen the handlebar bolts there's absolutely no need to replace them. Link to comment Share on other sites More sharing options...
Jayzonk Posted August 30, 2023 Author Share Posted August 30, 2023 So far, i've been living with it. Some of you are likely really good mechanics but i dont feel comfortable loosening my handlebar bolts and retightening, even if i had the proper torque specs. Link to comment Share on other sites More sharing options...
Ride365 Posted August 30, 2023 Share Posted August 30, 2023 13 hours ago, Jayzonk said: So far, i've been living with it. Some of you are likely really good mechanics but i dont feel comfortable loosening my handlebar bolts and retightening, even if i had the proper torque specs. Do you adjust/lube your chain or change your oil/filter? If the answer is yes......then you can loosen/tighten handlebar bolts and tighten back to spec. Link to comment Share on other sites More sharing options...
