vrex Posted May 8, 2015 Share Posted May 8, 2015 Has anyone installed a Vista Cruise Control on the FJ 09? I would like to know if there are any issues with this installation, particularly with heated grips. I would also like to hear of any other good cruise-control or throttle-lock options for this bike. Link to comment Share on other sites More sharing options...
troll Posted May 8, 2015 Share Posted May 8, 2015 http://cdn3.volusion.com/mwyus.wwtsk/v/vspfiles/photos/gocruise2-2T.jpg?1406570106 I just ordered a Go Cruise Coming to you from the frozen wastelands of the barren north Link to comment Share on other sites More sharing options...
ctrlaltdl Posted May 8, 2015 Share Posted May 8, 2015 It's not a Vista, but I zip-tyed a NEP throttle lock on. I've done the same to my 08 Truimph Sprint, and it's worked great for a couple years now. Link to comment Share on other sites More sharing options...
bucktownbilly Posted May 8, 2015 Share Posted May 8, 2015 http://cdn3.volusion.com/mwyus.wwtsk/v/vspfiles/photos/gocruise2-2T.jpg?1406570106 I just ordered a Go Cruise I use the plastic one...like it. Like it better than my throttlemister and it was a hell of a lot cheaper http://www.aerostich.com/go-cruisetm-throttle-control-1.html Link to comment Share on other sites More sharing options...
thruster8999 Posted May 8, 2015 Share Posted May 8, 2015 http://cdn3.volusion.com/mwyus.wwtsk/v/vspfiles/photos/gocruise2-2T.jpg?1406570106 I just ordered a Go Cruise I use the plastic one...like it. Like it better than my throttlemister and it was a hell of a lot cheaper http://www.aerostich.com/go-cruisetm-throttle-control-1.html Does the go throttle control work with the hand guard? Link to comment Share on other sites More sharing options...
redfjniner Posted May 8, 2015 Share Posted May 8, 2015 I am using the Go Cruise with the adjuster to tighten it up if necessary. It works but is harder to use than the Vista. The Vista Cruise will not work with OEM heated grips as the grip is preinstalled on the plastic tube and there isn't a large enough space left for the VC. Now the NEP is thinner as it is metal and may fit on the OEM heated grip assembly. I will look into it as the Go Cruise is much harder to use than the thumb activated devices and they stay locked in vs. the Go Cruise that will have to be reset all the time. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
redfjniner Posted May 8, 2015 Share Posted May 8, 2015 It's not a Vista, but I zip-tyed a NEP throttle lock on. I've done the same to my 08 Truimph Sprint, and it's worked great for a couple years now. Were you able to install w/o removing the grip? Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
ctrlaltdl Posted May 8, 2015 Share Posted May 8, 2015 Yes, you are able to back out the allen set screw, then it dissembles and your able to wrap it around the bar/throttle. I like the NEP brand better than Vista, simply because they are thinner (and cheaper), so you don't have clearance problems. Even though they are thinner they do seem to hold up for years and I've never worn one out yet. Now I just got to see if they will work with my backordered OEM heated grips. Link to comment Share on other sites More sharing options...
ctrlaltdl Posted May 11, 2015 Share Posted May 11, 2015 I just happen to have a Universal Vista Cruise in my garage. Here you can see that it won't fit without some modification. The mirror mount is in the way, and the throttle/controls are too thick. Link to comment Share on other sites More sharing options...
redfjniner Posted May 12, 2015 Share Posted May 12, 2015 Regarding the Universal Vista Cruise: I put one on mine, but it moved the brake lever to the left and throttle to the right and left a 2 finger operation for the brake. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
19ab Posted May 17, 2015 Share Posted May 17, 2015 Wife took away my credit card ,had to improvise 1,25$ throttle lock ,and it works!!!!! Link to comment Share on other sites More sharing options...
dndfindley Posted May 22, 2015 Share Posted May 22, 2015 Wife took away my credit card ,had to improvise 1,25$ throttle lock ,and it works!!!!!That got my attention. Home Depot carries them. More info please as to mounting and use. Link to comment Share on other sites More sharing options...
dndfindley Posted May 26, 2015 Share Posted May 26, 2015 One member posted that he used a Cable Cuff. I asked him to please explain how he used it. To date no replies. Hmmm...? Link to comment Share on other sites More sharing options...
jahx Posted May 28, 2015 Share Posted May 28, 2015 Regarding the Universal Vista Cruise: I put one on mine, but it moved the brake lever to the left and throttle to the right and left a 2 finger operation for the brake.If you had the spacer installed it would work. Link to comment Share on other sites More sharing options...
redfjniner Posted June 3, 2015 Share Posted June 3, 2015 Regarding the Universal Vista Cruise: I put one on mine, but it moved the brake lever to the left and throttle to the right and left a 2 finger operation for the brake.If you had the spacer installed it would work.That may be true if the spacer was long enough to be outside the brake lever. Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 114,000 m (Replaced engine at 106K) Link to comment Share on other sites More sharing options...
