jonm Posted January 21, 2016 Share Posted January 21, 2016 I picked up my brand new 2015 FJ-09 on Friday, 5 miles into the ride home got the check engine light! so at home checked out the Forum for code 069 and used that info to check the front ABS sensor which looked good, so at only 60 miles on the clock, took the bike back to the dealer last night, they checked it out and said I had codes 069 and 019 (Traction Control) they need to get parts, they said it was the sensor in the tire!! It was 6pm and they were closing so heading home I noticed that the front turn signals stay illuminated with the ignition on(first night ride) so I stopped to check and found also I had only one headlight, Is this normal??? When the service guy handed over the bike he commented that the headlights on the bike were bright! I guess that was also "service guy" Bull' to reassure the gullible customer that his brand new bike was fine. Am I right in believing that the bike needs a replacement "Electronic Brain" and not a Tire Sensor!? Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 21, 2016 Premium Member Share Posted January 21, 2016 I picked up my brand new 2015 FJ-09 on Friday, 5 miles into the ride home got the check engine light! so at home checked out the Forum for code 069 and used that info to check the front ABS sensor which looked good, so at only 60 miles on the clock, took the bike back to the dealer last night, they checked it out and said I had codes 069 and 019 (Traction Control) they need to get parts, they said it was the sensor in the tire!! It was 6pm and they were closing so heading home I noticed that the front turn signals stay illuminated with the ignition on(first night ride) so I stopped to check and found also I had only one headlight, Is this normal??? When the service guy handed over the bike he commented that the headlights on the bike were bright! I guess that was also "service guy" Bull' to reassure the gullible customer that his brand new bike was fine. Am I right in believing that the bike needs a replacement "Electronic Brain" and not a Tire Sensor!? It's a setup issue. The front ABS sensor mounts EXTERNALLY and provides inputs to the ECU for ABS and TCS...they effed up! If they simply remove the sensor and install properly, your problems will vanish. It's NOT inside the tire. Total incompetence which explains their inability to install the EXTERNAL sensor properly. Idiots! Only one headlight is illuminated on low-beam. Both come on when high-beam is switched on. The only "brain" that needs replacing is your local Yamaha dealer's. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Premium Member cman Posted January 21, 2016 Premium Member Share Posted January 21, 2016 What @clint said is right. My bike had the same problem. Unfortunately, it's common. Link to comment Share on other sites More sharing options...
thetruck454 Posted January 22, 2016 Share Posted January 22, 2016 I also had the same problem. I had to bend the tab back that holds the sensor in. It was bent from the sensor being installed wrong and bending the tab when the bolt was tightened. It always amazes me how many incompetent dealer are out there, it gives the few good ones a bad name. '15 FJ-09 with an aftermarket parts addiction Link to comment Share on other sites More sharing options...
Premium Member jeff400650 Posted January 22, 2016 Premium Member Share Posted January 22, 2016 My dealer found the same problem when prepping my bike for purchase. They figured it out and fixed it in a few minutes. That was 7500 miles ago. All is good. Pistons or pedals, 2 wheels are where it's at... Link to comment Share on other sites More sharing options...
papac2000 Posted January 26, 2016 Share Posted January 26, 2016 If you don't find these headlights bright, it could be they need aiming. Most here would attest they are awesome... 2015 Matte Grey Modded stock exhaust, modded stock screen, modded stock seat, OEM heated grips, LED indicators, FlashTuned ECU, ZX10R shock Link to comment Share on other sites More sharing options...
toast Posted January 26, 2016 Share Posted January 26, 2016 I think he was just noticing that only one headlight was lit up. OP, it's totally normal. One side is the high beam the other is the main beam. Link to comment Share on other sites More sharing options...
