duhs10 Posted April 1, 2016 Share Posted April 1, 2016 For those of you that have installed motodynamic's flush mount LED signals. Where did you place the resistors? I'm afraid to have it so close to the plastics since it seems to get very hot. Any advice would be awesome! '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted April 1, 2016 Premium Member Share Posted April 1, 2016 The wires were long so I zip tied them above the radiator. Let’s go Brandon Link to comment Share on other sites More sharing options...
duhs10 Posted April 1, 2016 Author Share Posted April 1, 2016 The wires were long so I zip tied them above the radiator. Did you install their sequential taillight as well? Wondering if I need to use both sets of resistors or if the ones for the taillight work for the whole system. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted April 1, 2016 Premium Member Share Posted April 1, 2016 Yes. Had to use both. Let’s go Brandon Link to comment Share on other sites More sharing options...
duhs10 Posted April 1, 2016 Author Share Posted April 1, 2016 thank you @micah2074.. back to the garage. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted April 1, 2016 Premium Member Share Posted April 1, 2016 You are welcome. Let’s go Brandon Link to comment Share on other sites More sharing options...
beanburnham Posted April 1, 2016 Share Posted April 1, 2016 Scrape the resistors and order a new flasher from TST industries. It was like twenty bucks and cleans up the wiring tremendously. Install of the flasher takes maybe 3 minutes Link to comment Share on other sites More sharing options...
duhs10 Posted April 1, 2016 Author Share Posted April 1, 2016 Scrape the resistors and order a new flasher from TST industries. It was like twenty bucks and cleans up the wiring tremendously. Install of the flasher takes maybe 3 minutes Was just looking at that.. I think I will go ahead and order one. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
duhs10 Posted April 1, 2016 Author Share Posted April 1, 2016 @beanburnham how would the TST flasher relay work with the motodynamics integrated tail light? They way it's wired I'm not sure how to delete the resistors.. there isn't a ground going into the resistor, but there is one coming out to the plug. The flush mounts will be straight forward with the flasher relay '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted April 1, 2016 Premium Member Share Posted April 1, 2016 The motodynamics instructions say to cut the black wire going to the resistor to disable it I believe. Let’s go Brandon Link to comment Share on other sites More sharing options...
beanburnham Posted April 1, 2016 Share Posted April 1, 2016 I had my buddy who is a master mechanic install the rear cuz I had the same question. I believe he kept the resistors on the rear and mounted them next to the tool kit tray instead of down the subframe rails like suggested by MotoDynamics. He said it was easier to keep the resistors for the integrated taillight only. The front flush mounts are easy plug and play now and I ran LEDs with the integrated taillight. With the flasher I don't have to worry about resistors on the rear LEDs. For twenty bucks it was an easy call to avoid resistors on the front flush mounts and additional rear LEDs Link to comment Share on other sites More sharing options...
beanburnham Posted April 1, 2016 Share Posted April 1, 2016 @beanburnham how would the TST flasher relay work with the motodynamics integrated tail light? They way it's wired I'm not sure how to delete the resistors.. there isn't a ground going into the resistor, but there is one coming out to the plug. The flush mounts will be straight forward with the flasher relay Pull your flasher before you order make sure it's the right one because they don't have the FJ-09 listed. I ordered the FZ and it wasn't the same. Had to return it and order the Gen2 I think it was disregard, I found it for you. https://tstindustries.com/LED-Flasher-Relay-Gen2.html Link to comment Share on other sites More sharing options...
duhs10 Posted April 2, 2016 Author Share Posted April 2, 2016 I found this.. http://www.fz09.org/forum/13-fz-09-gear-accessories/1081-motodynamic-integtated-tail-light-works-27.html And this... http://www.motodynamic.com/yamaha/wire-harness/yamaha-resistor-bypass-harness-for-any-motodynamic-sequential-led-tail-light.html '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted April 2, 2016 Premium Member Share Posted April 2, 2016 It's my understanding that the resistors will only heat up when the lights are flashing. I typically don't let my signals flash for very long. I have touched the resistors after long rides just to see how warm they get and they didn't seem to be hot at all. Let’s go Brandon Link to comment Share on other sites More sharing options...
beanburnham Posted April 2, 2016 Share Posted April 2, 2016 The bypass looks like it should work Link to comment Share on other sites More sharing options...
