desilva Posted February 7, 2017 Share Posted February 7, 2017 Hey guys. After a lot of research and suspensión tweaking I wanted to share my experience. One of the things that made me doubt on wether to buy the FJ09 or not was the head wobble. I based my setting on the MCN mag setup. I weight 85KG with full gear and had a lot of wobble with standard settings. My current settings make the bike track like an arrow and have almost no dive when breaking. Fork Preload: 2 Turns Out from full Fork Rebound: 8 Clicks Shock Preload: 4/7 Shock Rebound: 1 & 1/4 turns out from full. Try this setting. Its awesome! Hello nlukauskis, Could you kindly clarify a point for me - when you say 2 turns out from Full - do you mean 2 turns out from the tightest setting or in other words, Go clockwise all the way in and then go counter-clockwise 2 full turns? Is it the same principle for the Rear rebound too? Thanks a lot! Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 8, 2017 Supporting Member Share Posted February 8, 2017 Hello nlukauskis, Could you kindly clarify a point for me - when you say 2 turns out from Full - do you mean 2 turns out from the tightest setting or in other words, Go clockwise all the way in and then go counter-clockwise 2 full turns? Is it the same principle for the Rear rebound too? Thanks a lot! Suspension settings are "usually" worded as # clicks out (counter-clockwise) from full closed. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
desilva Posted February 27, 2017 Share Posted February 27, 2017 Hello All, I weigh about 190 lbs with full gear - so used a combination of norcal616 and nlukauskis. THANKS A LOT to both of them for documenting their settings! - result is that the bike is holding the line much better, no wobbly effect on curves, very little brake dive and overall good behavior! :-) Here are my final settings: Front forks: Preload, 24/64 inch from top of fork cap to bottom of adjuster. (about 1 cm) Rebound, 7 clicks out (ccw) from full in. Rear shock: Rebound, 1.25 turns out (ccw) from full in. Preload, position 5 from full soft. Read more: http://fj-09.org/thread/4703/best-settings-stock-suspension-me#ixzz4ZucMzQpn Link to comment Share on other sites More sharing options...
