catrike16 Posted January 23, 2017 Share Posted January 23, 2017 Does anyone have a link or can point me to where I can order a 2016 oil pan so I can do the swap? I looked on Yamaha website but can't seem to find it? Cheers? Link to comment Share on other sites More sharing options...
Premium Member bugsplatered Posted January 23, 2017 Premium Member Share Posted January 23, 2017 A FZ09 owner found it: http://www.fz09.org/forum/6-fz-09-general-discussion/10655-revised-09-oil-pan.html He listed the part as b56-13400 Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 23, 2017 Premium Member Share Posted January 23, 2017 Does anyone have a link or can point me to where I can order a 2016 oil pan so I can do the swap? I looked on Yamaha website but can't seem to find it? Cheers? Simply look for the oil pan for the XSR900. https://www.yocracing.com/accessory_store/store/yoc_advancedsearchexec_supersede.asp?keyword=B56-13400-00-00 Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
catrike16 Posted January 24, 2017 Author Share Posted January 24, 2017 For those that may have done the Fin removal, flush plug etc, how did you remove the Fin? Angle Grinder?? Link to comment Share on other sites More sharing options...
Premium Member clint Posted January 24, 2017 Premium Member Share Posted January 24, 2017 For those that may have done the Fin removal, flush plug etc, how did you remove the Fin? Angle Grinder?? Yeah, you can use an angle grinder, hacksaw, Dremel tool with cutoff blade. I'm not interested in the new oil pan as this mod does the trick. Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted January 24, 2017 Supporting Member Share Posted January 24, 2017 For those that may have done the Fin removal, flush plug etc, how did you remove the Fin? Angle Grinder?? Yeah, you can use an angle grinder, hacksaw, Dremel tool with cutoff blade. I'm not interested in the new oil pan as this mod does the trick.You can do the Mazda bolt replacement or another option is the drain bolt from an R1, I paid less than $2.50 for mine. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
