dpg34 Posted October 15, 2017 Share Posted October 15, 2017 Here's the story: I crashed into the back of a car at 10-15 mph. It broke the seal on my front tire, causing it to go flat within about 2 minutes. Also, the bike went down on its right side, hitting the bar end with enough force to slide the bars about 2/8" to the left. After fixing this, and having the front end aligned (had 2 different mechanics do it, then did it myself), the steering is still slightly off. To make the bike go straight, the bars and triple clamps are slightly to the right. Also, when I get the bike up to speed past 80, it starts to wobble, which did not happen before the crash. At this point, could it be bent forks? I'm reluctant to spend anymore money at motorcycle shops – I just don't trust them anymore. Link to comment Share on other sites More sharing options...
carey Posted October 15, 2017 Share Posted October 15, 2017 Have you confirmed that your rim, handlebars, triple clamps, and/or forks are straight? Link to comment Share on other sites More sharing options...
dpg34 Posted October 18, 2017 Author Share Posted October 18, 2017 I'm not sure how to measure these things, but I'm taking it to a new shop today which has good reviews; maybe third time is a charm Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted October 18, 2017 Supporting Member Share Posted October 18, 2017 @dpg34 - Good luck sorting it out. It’s hard to diagnose without seeing it in person, but the forks on these bikes are fairly stout, so would hope that nothing structural (forks, triples, axle) got bent. The handlebars, however, could have easily been bent with a direct impact at the end of the bar when it fell over... not sure that would explain a wobble at speed, however. When it was ‘aligned’, did you loosen everything in the front end (axles, pinch bolts, triple clamps, risers, bars) and bounce the front end to make sure it’s in place and not sticking anywhere? I’ve bought several wrecked bikes where the front was twisted fairly significantly, but it all came back in line with no permanent damage (and no bent parts) by carefully loosening and resetting/realigning to the correct orientation. Link to comment Share on other sites More sharing options...
FJ29ER Posted October 18, 2017 Share Posted October 18, 2017 My bike got knocked over standing still and bent the bars about 1/8. And after two trustful mechanics say the bike felt fine it still did not feel right to me (I have been riding this bike for 10k miles,If something is not right I know, they have not so I understand ho wit could feel fine for them). So I replaced with new bars and all was good again. I am almost positive you have bent bars as well. Here is my thread https://fj-09.org/thread/5832/ing-harleys-bent-front-end Link to comment Share on other sites More sharing options...
dpg34 Posted October 19, 2017 Author Share Posted October 19, 2017 Thanks for your advice- I should determine if the bars are bent; the front wheel may be bent as well, since I was riding on a flat on the highway until I reached a safe spot to stop. I might be dealing with multiple problems Link to comment Share on other sites More sharing options...
FJ29ER Posted October 19, 2017 Share Posted October 19, 2017 Yea. The way I did it before I purchased new ones is lay my bars on a flat surface, push down on where the bar mounts go (the center) and see if one side (where the grips go) lifts up. I doubt the riding on a flat did anything but the impact could have flat spotted the rim, but at 10-15...I doubt it. Link to comment Share on other sites More sharing options...
dpg34 Posted June 4, 2018 Author Share Posted June 4, 2018 Really sorry to resurrect this old thread, but this is important to pass on; I found the reason my bike felt “cockeyed”, like it was somewhat pulling to one side, and the handlebars weren’t aligned. After many visits to motorcycle shops, many dollars wasted on multiple alignments, and finally, replacing the handlebars (which were not bent), I figured it out. I spent $15 on amazon to buy a motion pro alignment tool, clamped it on the rear sprocket, and “voila”, my rear wheel was out of alignment, hence that “crabbing” effect I’d been experiencing. After fixing this, the bike rode like brand new again- it was amazing. The best $15 I’ve ever spent. I figured out that most, if not all the motorcycle shops I’d been to, were using the swing arm marks to line the wheel, which was inaccurate. Moral of the story, if your steering feels off, and your front wheel is aligned, check your rear wheel with this tool. Link to comment Share on other sites More sharing options...
koth442 Posted June 4, 2018 Share Posted June 4, 2018 Oh wow. Happy you got it sorted, bummer it was such a PITA to do so. '15 FJ09 Link to comment Share on other sites More sharing options...
dpg34 Posted June 4, 2018 Author Share Posted June 4, 2018 Thanks; I'm going to probably make a new post about this fix; maybe it will save someone else the expense and time. Link to comment Share on other sites More sharing options...
angrygirafe Posted June 4, 2018 Share Posted June 4, 2018 Don’t forget to take that tool off your sprocket after alignment. It will drastically reduce chain life otherwise. Guess how I know...☹️ Link to comment Share on other sites More sharing options...
koth442 Posted June 4, 2018 Share Posted June 4, 2018 Don’t forget to take that tool off your sprocket after alignment. It will drastically reduce chain life otherwise. Guess how I know...☹️ I shouldn't laugh at your misfortune, but that gave me a chuckle. We've all done outrageously silly things. I left paper towels in the velocity stacks of my Daytona 675 then wondered why my bike wouldn't idle. '15 FJ09 Link to comment Share on other sites More sharing options...
Premium Member Henchman Posted June 4, 2018 Premium Member Share Posted June 4, 2018 Really sorry to resurrect this old thread, but this is important to pass on; I found the reason my bike felt “cockeyed”, like it was somewhat pulling to one side, and the handlebars weren’t aligned. After many visits to motorcycle shops, many dollars wasted on multiple alignments, and finally, replacing the handlebars (which were not bent), I figured it out. I spent $15 on amazon to buy a motion pro alignment tool, clamped it on the rear sprocket, and “voila”, my rear wheel was out of alignment, hence that “crabbing” effect I’d been experiencing. After fixing this, the bike rode like brand new again- it was amazing. The best $15 I’ve ever spent. I figured out that most, if not all the motorcycle shops I’d been to, were using the swing arm marks to line the wheel, which was inaccurate. Moral of the story, if your steering feels off, and your front wheel is aligned, check your rear wheel with this tool. I bought the same tool to do my first ever chain install and it works a treat. No crabbing here either. Link to comment Share on other sites More sharing options...
