Premium Member joeszup Posted December 17, 2017 Premium Member Share Posted December 17, 2017 Doing my 8k maintenance and I've not seen this before on any of my bikes. During the 4k maintenance, I did remove all the plugs and verify that they looked good, checked the gap and reinstalled them. It looks like this plug has a burn mark on it and is crusted white, almost like oxidation, but not quite (see the red box and red circles). Is this a bad plug or do I have bigger issues here? Center plug from the bike. Link to comment Share on other sites More sharing options...
BBB Posted December 17, 2017 Share Posted December 17, 2017 Both those areas you circled are outside the combustion chamber of the piston, so they are not involved in making the spark. It looks like there is surface corrosion from exposure to a damp environment, which is not surprising in winter. No idea what the dark mark is though. Hard to tell from this angle, but the tip looks fine. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Premium Member joeszup Posted December 17, 2017 Author Premium Member Share Posted December 17, 2017 Both those areas you circled are outside the combustion chamber of the piston, so they are not involved in making the spark. It looks like there is surface corrosion from exposure to a damp environment, which is not surprising in winter. No idea what the dark mark is though. Hard to tell from this angle, but the tip looks fine. Yeah, the tip is normal with a little carbon. I do ride year round, so maybe I didn't get the plug cap seated all the way. Link to comment Share on other sites More sharing options...
koth442 Posted December 17, 2017 Share Posted December 17, 2017 Dark mark could be a finger print? Dunno. As said above, its outside the combustion chamber -> non issue. '15 FJ09 Link to comment Share on other sites More sharing options...
Dark&Stormy Posted December 20, 2017 Share Posted December 20, 2017 That is likely dissimilar metal corrosion due to galvanic action between the aluminum head and metal spark plug body. I wouldnt be too concerned as long as you change your spark plugs periodically. Link to comment Share on other sites More sharing options...
Dark&Stormy Posted December 20, 2017 Share Posted December 20, 2017 The dark spot is likely an oil spot and prevented corrosion by blocking oxygen and water from the metal surface. Link to comment Share on other sites More sharing options...
Premium Member joeszup Posted December 21, 2017 Author Premium Member Share Posted December 21, 2017 Thanks Dark&Stormy! Link to comment Share on other sites More sharing options...
