Supporting Member scjaws Posted February 1, 2018 Supporting Member Share Posted February 1, 2018 I'm looking for the Turn Signal fuse. My turn clickers died and it seems people don't recognize hand signals. The shop manual doesn't make the location very clear. Any help will be appreciated. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted February 1, 2018 Supporting Member Share Posted February 1, 2018 On the fuse block located on the right side by the radiator cap, the manual lists "Signaling System fuse 7.5A" as location 5. Swap that out and see if it fixes your signals. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member washufiddyfo Posted February 2, 2018 Premium Member Share Posted February 2, 2018 On mine, it was definitely in the fuse panel on the right side. But when I was working on mine a while back, I learned my turn signals were wired to the parking/running light fuse, and park/running lights were wired to the turn signal fuse (either wired incorrectly or mislabeled) So if you pull your flasher fuse and it looks fine, check the park light one. Link to comment Share on other sites More sharing options...
