BBB Posted May 18, 2018 Share Posted May 18, 2018 The next two jobs on my list are to take the tank off and do the APS adjustment and check the throttle bodies are synchronised. So, my question is: is there a particular order that is best i.e. APS first then synch, or vice-versa? Or are the systems independent and it doesn’t matter? Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
koth442 Posted May 18, 2018 Share Posted May 18, 2018 Subscribed. '15 FJ09 Link to comment Share on other sites More sharing options...
BBB Posted May 19, 2018 Author Share Posted May 19, 2018 Thanks @piotrek, for the clear explantion. That confirms my own view but I always like to check with folk who are wiser than myself. I don’t have poor idle but just want to check both when the tank is off. The bike just doesn’t feel as quick to accelerate but I strongly supect that this is me being used to how it performs and my own shift in expectations. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
skipperT Posted May 21, 2018 Share Posted May 21, 2018 Also just to put it out there, valve clearances should be checked and corrected if necessary BEFORE doing a TB sync. Many of us are approaching or beyond the first recommended inspection interval. Based on recent threads and my own bike I personally would recommend getting valve clearances checked anywhere after 20k miles, not waiting for the 26k mark. Carbon build up in the Throttle Plates and TB’s can affect both the sync and APS/TPS adjustment, just so you’re aware. -Skip T Link to comment Share on other sites More sharing options...
