Premium Member DavidS Posted October 23, 2018 Premium Member Share Posted October 23, 2018 I have a 2015 FJ09, and have slowly added a number of devices that require electrical power. (GPS, Heated Seat, etc.) I'm an electrical idiot, but I want to make sure I'm not overloading the capacity of the bike. I have seen the power hub's advertised to centralize the wiring in one place, as opposed to connecting everything to the battery terminals, but before I go buy something, I thought I would ask here to see what other folks are doing/using to solve this issue. Any advise or rules of thumb are appreciated. Link to comment Share on other sites More sharing options...
nsmiller Posted October 24, 2018 Share Posted October 24, 2018 You may find this helpful: http://www.powerlet.com/learningCenter/excessCapacity Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted October 24, 2018 Supporting Member Share Posted October 24, 2018 I created a list and decided that all I needed was a simple unswitched 3-circuit pod from Cycle Terminal. It easily tucks away under the seat and doesn't require any real estate for a box. This freed up precious space for an air pump. The 8-circuit fuse boxes are nice, but way too bulky IMO, and they're not splash-proof. My gadget list: [ul type=disc][*]Fog lamps - switched, auxiliary behind dash [*]Bar mounted USB pod - switched, in parallel (shared) with 12V Powerlet socket[*]GPS - switched, auxiliary behind dash[*]Cruise - per instructions (Y-adapter off run light I believe) [*]Fiamm horn - OE circuit [*]Oxford heated grips - unswitched (auto-off controller), 3-circuit pod (circuit 1) [*]Heated jacket - unswitched (heat controller) 3-circuit pod (circuit 2)[*]Battery tender / air pump / aux Powerlet port - unswitched, 3-circuit pod (circuit 3)[/ul] Lots of ideas out there, but this works for me very well. The only non-OE accounted loads that would run concurrently on the bike would be the jacket and the heated grips, so say 10-12A max. Not significant. Link to comment Share on other sites More sharing options...
bugie Posted October 24, 2018 Share Posted October 24, 2018 This might be of use: [url=]https://fj-09.org/thread/5752/when-get-wiring-block[/url] Link to comment Share on other sites More sharing options...
YamaGeezer Posted October 27, 2018 Share Posted October 27, 2018 I am considering trying one of these. https://www.summitracing.com/parts/msd-7564. Anyone else tried one? Link to comment Share on other sites More sharing options...
Premium Member Brick Posted October 27, 2018 Premium Member Share Posted October 27, 2018 I’ve used a number of these over the years. This is the best one I’ve found. https://www.fuzeblocks.com/Fuzeblocks-FZ-1-Distribution-Block_p_1.html Brick 2015 Yamaha FJ-09 "Red Molly" 2014 Yamaha Super Tenere' ES 1999 Suzuki SV650 Link to comment Share on other sites More sharing options...
