BrianG Posted November 8, 2020 Share Posted November 8, 2020 While I understand that the R1 cable is somewhat longer than the OEM FJ 09 cable, I have changed my handlebars and would like a clutch cable that is substantially (maybe +6") longer than the original. Does anyone know if there is such an animal available from some other Yamaha model, or perhaps even from a different marque? Link to comment Share on other sites More sharing options...
david Posted November 8, 2020 Share Posted November 8, 2020 motion pro can make one Link to comment Share on other sites More sharing options...
BrianG Posted November 8, 2020 Author Share Posted November 8, 2020 (edited) Excellent! Thanks. Can anyone provide the total outer length and the inner cable length of the OEM cable? Edited November 8, 2020 by BrianG Link to comment Share on other sites More sharing options...
whisperquiet Posted November 8, 2020 Share Posted November 8, 2020 (edited) 1 hour ago, BrianG said: While I understand that the R1 cable is somewhat longer than the OEM FJ 09 cable, I have changed my handlebars and would like a clutch cable that is substantially (maybe +6") longer than the original. Does anyone know if there is such an animal available from some other Yamaha model, or perhaps even from a different marque? Motion Pro makes custom length cables. So does Terry Cables. Welcome to TerryCable - Racing Products Motion Pro Motion Pro - High quality cables, tools and controls for motorcycles, ATVs... Quote Edited November 8, 2020 by whisperquiet Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 9, 2020 Supporting Member Share Posted November 9, 2020 5 hours ago, BrianG said: I have changed my handlebars and would like a clutch cable that is substantially (maybe +6") longer than the original. Just how tall are the bars you installed that you need +6" longer clutch cable? If you need a +6" clutch cable then for sure you will also need longer throttle cables and brake line as well. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
BrianG Posted November 9, 2020 Author Share Posted November 9, 2020 (edited) 14 hours ago, betoney said: Just how tall are the bars you installed that you need +6" longer clutch cable? If you need a +6" clutch cable then for sure you will also need longer throttle cables and brake line as well. The new bars have more sweep and some drop, rather than the rise of the OEM bars. This changes the angle of the clutch perch upward, and forward requiring a re-routing of the cable around the right side of the steering head and a different cable arch than that provided by the elbow housing at the upper end of the OEM cable . A mock-up suggests that 6" more length will do it. With a little re-routing, the current wiring, front brake line and throttle cables well accommodate the new bars. Edited November 9, 2020 by BrianG 2 Link to comment Share on other sites More sharing options...
BrianG Posted November 9, 2020 Author Share Posted November 9, 2020 I still need the numbers for the total outer cable casing length (including the elbow) and the inner cable length of the OEM cable, please. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 11, 2020 Premium Member Share Posted November 11, 2020 The housing is about 46 inches. the cable is about 49.25 inches 1 Let’s go Brandon Link to comment Share on other sites More sharing options...
BrianG Posted November 11, 2020 Author Share Posted November 11, 2020 4 hours ago, micah2074 said: The housing is about 46 inches. the cable is about 49.25 inches Thank you! Link to comment Share on other sites More sharing options...
