petshark Posted May 11, 2021 Share Posted May 11, 2021 My new Lightech stand arrived today. It fits perfect, has a small footprint, is light and seems well-made but the pin can't go in on the left because of the pinch bolt. Never thought of that.. It works like this but I don't want the bolt to get damaged over time. So I'm thinking to take the angle grinder to the new stand and make the pin small enough to just fit underneath but I'm not sure if it will still "grab" the hole that way. And it would be a shame to break it (I don't have any welding tools) Has anyone done this or know a better solution? Thanks! Link to comment Share on other sites More sharing options...
Supporting Member Warchild Posted May 11, 2021 Supporting Member Share Posted May 11, 2021 Not trying to be snarkey, but... Pit Bull stands have no equal: 1 Link to comment Share on other sites More sharing options...
petshark Posted May 11, 2021 Author Share Posted May 11, 2021 That looks good! Lightech offers that model as well if I'm not mistaken but I liked the simplicity of the pin system. Most importantly I can't send it back so I have to find a way to make it work. Link to comment Share on other sites More sharing options...
peteinpa Posted May 11, 2021 Share Posted May 11, 2021 If you're using it while on the center stand also it's not holding much weight. I don't think it's a problem. 1 Link to comment Share on other sites More sharing options...
Supporting Member Warchild Posted May 11, 2021 Supporting Member Share Posted May 11, 2021 I would be concerned about grinding down the pin on the pinch bolt side, for reasons you've mentioned. It would be tragic if the bike fell due to a slight bump, etc. If you only use the stand for tire-changing/maintenance purposes, then I would just remove the pinch bolt altogether before lifting. But if you intend to use the stand frequently for non-maintenance reasons, then it would be a pain to remove the pinch bolt all the time. There may not be a good answer here, in that regard. 1 Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted May 11, 2021 Premium Member Share Posted May 11, 2021 My handy stands do that. I remove the bolt before putting her on the stand. Then put it back in when she come down. It takes just a few seconds. Been doing this for years and never a problem. 1 Let’s go Brandon Link to comment Share on other sites More sharing options...
