Tyghazi Posted February 9, 2022 Share Posted February 9, 2022 Hello, all. This is my first post about my new-to-me 2016 FJ-09. I have been adding bits and pieces gradually, and today’s addition was a Kisan headlight modulator. I swear by these devices, which have saved me more than once. Since I ride in groups quite often, I needed a way to shut off the modulator when in the middle of the pack, and just run with the bright lights full on without flashing. All I really needed was a cap for the sensor. I ended up using a spare cap from a heated gear cable, which I modified by digging the “stem” out of the cap. It ended up being a perfect fit. Have a look at the “on” and “off” pics attached. All the best, Tarek 1 Link to comment Share on other sites More sharing options...
petshark Posted February 9, 2022 Share Posted February 9, 2022 Really interesting. I'm going to look into this. Thanks Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted February 9, 2022 Premium Member Share Posted February 9, 2022 Did you buy the Nisan plug n play modulator for Yamaha LED headlights? If so, I developed that with Andy Gandhi at Kisan. BTW, if you ask, they also have a version with a longer cable to mount it farther from the HLC unit. Personally, if I was riding behind a buddy, let alone several, I'd never have my high beam on. Almost any modern high beam, LED or not is annoyingly bright in my mirrors anyway... Link to comment Share on other sites More sharing options...
