Supporting Member knyte Posted October 14, 2023 Supporting Member Share Posted October 14, 2023 10 hours ago, DHDad said: am amazed there aren't more posts about rear sets, foot pegs on this forum. I've wondered this myself, and chalked it up to a lack of available options - the choices aren't compelling. I was able to move my shifter up a few splines, so good enough, but it'd be nice to move the pegs down a bit instead. 1 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
DHDad Posted October 14, 2023 Share Posted October 14, 2023 16 hours ago, OldBikers said: I have no issues with my size 45 (10.5 US) shifting. I did notice that the thicker soles of my hiking boots does impede shifting a little bit but still usable. My Daytona riding boots do have very thick soles but not an issue on my other two bikes Link to comment Share on other sites More sharing options...
DHDad Posted October 14, 2023 Share Posted October 14, 2023 6 hours ago, knyte said: I've wondered this myself, and chalked it up to a lack of available options - the choices aren't compelling. I was able to move my shifter up a few splines, so good enough, but it'd be nice to move the pegs down a bit instead. I will report back on how the Puig setup works or doesn't once I get them installed 1 Link to comment Share on other sites More sharing options...
etex Posted October 14, 2023 Share Posted October 14, 2023 I wear size 12 boots and found the clearance to get my toe under the shifter too small. I adjusted the length of the shift rod to raise the shifter peg a bit. For me, problem solved. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 14, 2023 Premium Member Share Posted October 14, 2023 Is a stated before I lowered and move slightly forward with wider and longer adjustable pegs And for the rear brake Knocked in the heal guard for more clearance When you're back in the peg Link to comment Share on other sites More sharing options...
OZVFR Posted October 14, 2023 Share Posted October 14, 2023 On 10/14/2023 at 5:25 AM, DHDad said: I am amazed there aren't more posts about rear sets, foot pegs on this forum. Tried both positions and find it almost impossible to get my riding boot toe under the shifter. I'm not big foot either, size 42 riding boot/9.5 US. Pic ^^^ from 2and3cylinders appears to be an older 900 not a 9 GT. I just measured the distance between the center of the foot peg to the center of the shifter on all my bikes. My Monster is 6.25", Ninja 6" and Tracer only 5.5" plus the fattest of the foot pegs and biggest diameter rubber cover on the shifter making the distance even smaller. Not many options either I've found. Woodcraft makes rear sets but they state "for racing only" as they don't fold. Plus quite pricey. I'm going to give the Puig foot pegs with the 20mm 360 degree adjuster, should at least get me back to the distance I have on the other bikes. It seems a silly question, but have you adjusted the gear lever up? I have size 43 boots that are very heavy duty and have no problems with fit under it. it’s a bit too high when I wear my summer short ventilated boots but not enough to readjust. Link to comment Share on other sites More sharing options...
Yaman Posted October 15, 2023 Share Posted October 15, 2023 I replaced mine with oem tracer 700 footpegs 1 Link to comment Share on other sites More sharing options...
Yaman Posted October 15, 2023 Share Posted October 15, 2023 1 Link to comment Share on other sites More sharing options...
DHDad Posted October 17, 2023 Share Posted October 17, 2023 On 10/14/2023 at 7:59 PM, OZVFR said: It seems a silly question, but have you adjusted the gear lever up? I have size 43 boots that are very heavy duty and have no problems with fit under it. it’s a bit too high when I wear my summer short ventilated boots but not enough to readjust. Yes I have, Yaman is your's a 9 GT? That shifter looks nothing like mine. Maybe you have the older model? Link to comment Share on other sites More sharing options...
Yaman Posted October 17, 2023 Share Posted October 17, 2023 I have a 2019 900 gt . The shifter is bent inwards, i tried to bend it back but its crap cast aluminium and i was afraid it would snap so i ordered a new, 2 cm longer . Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 17, 2023 Premium Member Share Posted October 17, 2023 Sargent is +1" and wider, longer pegs are -3/4" & forward +5/8" Street Naked bars are higher with more rearward sweep Link to comment Share on other sites More sharing options...
The Cheese Posted October 17, 2023 Share Posted October 17, 2023 Any recommendations for higher footpegs? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 18, 2023 Premium Member Share Posted October 18, 2023 18 minutes ago, The Cheese said: Any recommendations for higher footpegs? The pegs you see on my bike rotate 360 so you can bring them up and back if you want easy peasy and pretty damn cheap good quality have held up to my girth! Don't know why you'd want to though because the FJ tracer et cetera are designed to be comfortable not a sport bike necessarily. I rented a 16 in San Diego in March and some idiot had put on a set of rear sets, they were just awful, painful and it shifted like crap, so I wouldn't advise it Link to comment Share on other sites More sharing options...
The Cheese Posted October 18, 2023 Share Posted October 18, 2023 22 hours ago, 2and3cylinders said: The pegs you see on my bike rotate 360 so you can bring them up and back if you want easy peasy and pretty damn cheap good quality have held up to my girth! Don't know why you'd want to though because the FJ tracer et cetera are designed to be comfortable not a sport bike necessarily. I rented a 16 in San Diego in March and some idiot had put on a set of rear sets, they were just awful, painful and it shifted like crap, so I wouldn't advise it I have a Russell Daylong on my bike. Which raises the seating position. The distance to the pegs was borderline before the new seat. Is it ok with you if I try to make my bike comfortable to me? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 18, 2023 Premium Member Share Posted October 18, 2023 When you say rearsets I presumed you wanted something like racing style pegs that are up and back, excuse me if I misunderstood you. The pegs I have may be you exactly what you're looking for, down and forward a bit. Link to comment Share on other sites More sharing options...
