Ride365 Posted July 4 Share Posted July 4 I mostly run ester Motul 7100 and have zero oil usage far as I can tell between 4K mile intervals, and I ride plenty HARD.......and the shifting is butter clear up to the change, and engine/clutch mechanical noise is practically non existent. Yup it is expensive, and yup it is worth every cent IMHO. Much love for the Mobil 1 4T as well, these are my 2 favorite and most used "synthetic" oils. Looks like Motul has a new line of oil now, may have to give it a try. 😎  https://www.motul.com/en-US/products/16505?product=MOTUL+NGEN+7+10W-40+4T 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 4 Supporting Member Share Posted July 4 5 hours ago, 2and3cylinders said: I see a six pack on Amazon for 55 bucks or only 9.16 per quart or liter but it's 10w50 I just found 10W-40 for 59 bucks for 9.83 a liter Is the latter what you get B-man? You going for a ride today Yes, 10w40. I get the six pack either on Amazon or Ebay depending if it is out of stock or on sale. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
MikeD Posted July 5 Author Share Posted July 5 I care about your personal opnion jthayer, especially after writing what I consider super good information, about the ma2 and synthetic base. 1 Link to comment Share on other sites More sharing options...
MikeD Posted July 5 Author Share Posted July 5 (edited) Thanks again everyone . Good all around coverage on the subjec. I have used the Mobil 1 4 t myself a lot. And motul 7100 a lot. I wonder if that new motul stuff is any different, I see now that it is not synthetic base. was glad to hear about the 10w 40 being most preferred weight   Edited July 5 by MikeD 1 Link to comment Share on other sites More sharing options...
OZVFR Posted July 5 Share Posted July 5 Only use 10W50 here, it gets too hot in summer for 10W40 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted July 5 Premium Member Share Posted July 5 My beloved T6 is 5W-40, as it can be 65F here in June and 45 in May and September. However, I will try the Castrol 1 next season. 1 Link to comment Share on other sites More sharing options...
Ride365 Posted July 5 Share Posted July 5 7 hours ago, MikeD said: Thanks again everyone . Good all around coverage on the subjec. I have used the Mobil 1 4 t myself a lot. And motul 7100 a lot. I wonder if that new motul stuff is any different, I see now that it is not synthetic base. was glad to hear about the 10w 40 being most preferred weight   Cannot go wrong with either of course, and I would stick with 10W40 where you are as well, a 50 weight IMHO is for big piston air cooled twins "likely still overkill". Also that new Motul does appear to have plenty of ester in it, but I will likely stick with the 7100.  Description MOTUL NGEN 7 is a best-in-class 4-stroke motor oil based on a combination of finest virgin base oils and additives blended with synthetic esters and high quality regenerated base oils.Suitable for any type of high performance street or off-road motorcycle with 4-stroke engine, with or without integrated gearbox, wet or dry clutch. Perfect for motorcycles with exhaust after-treatment systems such as catalytic converters or secondary air injection.Designed for severe conditions in sport and adventure riding.Other applications: ATVs, UTVs, SxS, personal watercraft (PWC) or snowmobiles depending on manufacturer’s viscosity recommendation. Link to comment Share on other sites More sharing options...
DubT9 Posted July 7 Share Posted July 7 Think that new motul ngen uses recycled oil in the mix. I'll wait on feedback before giving it a try and ill continue using motul 5100 10w40 which I've used for years in all my bikes without issues. Link to comment Share on other sites More sharing options...
OZVFR Posted July 8 Share Posted July 8 (edited) A lot of people miss-interpret the meaning of the viscosity numbers. 10W50 means it has the viscosity of a 10 weight oil when cold, but behaves like a 50 when hot. The problem with going to  a 5W oil on a motor that is specified a 10W, is that it might be too thin for the oil pump to operate at the required pressure.  10W oil is specified down to -10*C or 10*F. No 5W is shown in the manual specs. 40W is only good to 40*C, in summer I often ride above this. In a memorable 3 day trip a few years ago it was 46C and I was fanging the bike for over 3 hours straight. 10W50 is still a 10W oil, nothing to do with big or small motors. Everyone has different opinions, and I don’t think you would damage the motor by using 5W40, but I don’t see the point. Some of the top oils are however stupidly expensive, they mainly promise some special ingredient that is secret and only they have the recipe. I just buy whatever is on special from any of the known brands. Have never had a problem with lubrication, 10W50 fits the conditions I ride in on this bike.  Don’t you love an oil thread? Edited July 8 by OZVFR 1 Link to comment Share on other sites More sharing options...
MikeD Posted July 26 Author Share Posted July 26 (edited) What I thought was interesting was that they didn't list 15W 50. My manual also says something like "it is not recommended to use oils of a higher quality or rating than what is listed." My oil (when I us mobil 1 -4 stroke full synthetic 10 W 40) seems to go dark faster than I would like. I ride a lot. I am not putting wacky additives in fuel or oil or anything, so I'm not sure why this specific oil goes dark so quick. I like to change my oil sometimes even after 1000 miles if I have been riding a bit aggressive with the mobil 1.  The Motul 7100 I also use seems to last a bit longer, but I still change before 2000 miles. My initial question was whether 15 W 50 or 20 W 50 would be better in my 100 degree weather area. But most folks around here still prefer 10 W 40. Edited July 26 by MikeD Link to comment Share on other sites More sharing options...
Ride365 Posted July 26 Share Posted July 26 2 hours ago, MikeD said: What I thought was interesting was that they didn't list 15W 50. My manual also says something like "it is not recommended to use oils of a higher quality or rating than what is listed." My oil (when I us mobil 1 -4 stroke full synthetic 10 W 40) seems to go dark faster than I would like. I ride a lot. I am not putting wacky additives in fuel or oil or anything, so I'm not sure why this specific oil goes dark so quick. I like to change my oil sometimes even after 1000 miles if I have been riding a bit aggressive with the mobil 1.  The Motul 7100 I also use seems to last a bit longer, but I still change before 2000 miles. My initial question was whether 15 W 50 or 20 W 50 would be better in my 100 degree weather area. But most folks around here still prefer 10 W 40. No good scientific reason, why you are changing out a true PAO Ester synthetic at that mileage.....you are literally throwing away like new oil. Also, NEVER go by the color of the oil, that is zero indication of how good/bad it is. 3 1 Link to comment Share on other sites More sharing options...
kilo3 Posted July 27 Share Posted July 27 14 hours ago, MikeD said: The Motul 7100 I also use seems to last a bit longer, but I still change before 2000 miles. Damn, can I have your "used" oil? 1 2 Link to comment Share on other sites More sharing options...
Ride365 Posted July 27 Share Posted July 27 10 hours ago, kilo3 said: Damn, can I have your "used" oil? I hear ya, I'd happily dump that into my R1200 GS......which my 4L jug of fresh unicorn blood is arriving this evening. 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 27 Supporting Member Share Posted July 27 On 7/26/2024 at 6:14 AM, MikeD said: I ride a lot. I am not putting wacky additives in fuel or oil or anything, so I'm not sure why this specific oil goes dark so quick. I like to change my oil sometimes even after 1000 miles if I have been riding a bit aggressive with the mobil 1. The Motul 7100 I also use seems to last a bit longer, but I still change before 2000 miles. Not criticizing but just my opinion, -that seems grossly excessive and wasteful, not to mention time consuming and expensive. If concerned about any specific oil you could always have it analyzed - Blackstone Labs Oil Analysis that way you could know for sure if your interval is justified or if you are throwing money and resources away. Motul 7100 is over $20 a liter!!! 2 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted July 27 Premium Member Share Posted July 27 What's "I ride a lot"? Beyoney (Brian) rides a fair amount more than me (I've have maybe a few good reasons I've had to limit my mileage) and while possibly Brian also doesn't think you've been pulling our legs about your oil change intervals, I have good reason to suspect that. As B-Mand suggested, a lubricant analysis costs only a bit more than a liter of Motul. Please know I think you "protest too much", and ask that you don't waste our time, snd, if you're not jesting, your shekels more, and that you get a life! Â 2 Link to comment Share on other sites More sharing options...
