zachd Posted September 26, 2015 Share Posted September 26, 2015 Let's be honest, we all want to be seen as much as possible. I didn't want to break my bank on a set of OEM or Denali driving lights. After a quick search on Amazon, I found a nice set of Nilight® 2 X 18w 1260lm Cree LED Spot Driving Lights (here) for only $23, which had some pretty bitchin' reviews (over 1,350 @ 4.6/5 stars), so I decided to give them a whirl. Looking at the bike and where I could possibly mount them, I made some quick measurements to see what kind of bracket I could potentially use. I ended up ordering a metal bracket from Amazon. The brackets needed to be rounded out on the holes to accommodate the bolts provided in the kit. I used all the provided hardware from the kit and oem bolts, plus a few additional washers I had laying around. I painted the brackets to try and match the color of the fender with some spray paint I had laying around from a previous project. I wired them into an add-a-circuit fuse, so they turn on when the bike is on and off when the bike is turned off. But I also wired them through a rocker switch, so I can turn them on/off when I want as well. I installed this on the plastic trip piece that goes around the top of the tank. These lights are so worth the money. They are extremely bright at night, almost overpowering the high beam! I know I am definitely seen more during the day and nighttime, which has added a level of comfort. Parts: Bullet Electrical Connectors 3/8" Plastic Conduit (to hide wiring) Mini Add-A-Circuit 16g Wire Nilight Driving Lights Brackets Link to comment Share on other sites More sharing options...
bobbycnote Posted September 26, 2015 Share Posted September 26, 2015 Looks Great! Link to comment Share on other sites More sharing options...
adjuster Posted September 26, 2015 Share Posted September 26, 2015 Night photos please! Looks great. Link to comment Share on other sites More sharing options...
goldfishlung Posted September 27, 2015 Share Posted September 27, 2015 This is pretty awesome. Would you mind telling me about your wiring? I am a noob at anything electrical. I've never heard of Add-a-circuit before and it seems really interesting. Which fuse did you tap into and does it matter what fuse you tap into? Link to comment Share on other sites More sharing options...
Premium Member wessie Posted September 27, 2015 Premium Member Share Posted September 27, 2015 This is pretty awesome. Would you mind telling me about your wiring? I am a noob at anything electrical. I've never heard of Add-a-circuit before and it seems really interesting. Which fuse did you tap into and does it matter what fuse you tap into? I had not seen an Add-a-circuit before myself, but as usual, google provides the answer This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
goldfishlung Posted September 27, 2015 Share Posted September 27, 2015 Thanks Wessie. I am just unsure if it matters which fuse I tap into. On my previous bike I wired a relay for heated grips, but that is time consuming and messy. Link to comment Share on other sites More sharing options...
zachd Posted September 27, 2015 Author Share Posted September 27, 2015 Yep, thats exactly what I used. I tapped into the "AUX" fuse. These dont draw a whole lot of power, so you dont need much more than a 5amp fuse. The switch I installed is a 3 way switch. So on the back of it, it has a load, power, and ground terminal. Plug in your add-a-circuit, and run a wire from that to the "power" terminal. I opted to not run a negative wire to the switch because the LED light on the switch is really bright and annoying, quite frankly. As for the wiring for the lights, I spliced them together. Then you run a wire from the "load" terminal, to the positive connector on the lights. Run your ground wire to the negative of the lights. Tidy everything up, and you're done. I will try to take some night pictures soon, and post them. Link to comment Share on other sites More sharing options...
goldfishlung Posted September 27, 2015 Share Posted September 27, 2015 Yep, thats exactly what I used. I tapped into the "AUX" fuse. These dont draw a whole lot of power, so you dont need much more than a 5amp fuse. The switch I installed is a 3 way switch. So on the back of it, it has a load, power, and ground terminal. Plug in your add-a-circuit, and run a wire from that to the "power" terminal. I opted to not run a negative wire to the switch because the LED light on the switch is really bright and annoying, quite frankly. As for the wiring for the lights, I spliced them together. Then you run a wire from the "load" terminal, to the positive connector on the lights. Run your ground wire to the negative of the lights. Tidy everything up, and you're done. I will try to take some night pictures soon, and post them. Thank you Zachd, that would be extremely helpful. Just curious where you connected your ground wire? Did you just connect to any bare metal bolt on the frame? Link to comment Share on other sites More sharing options...
zachd Posted September 28, 2015 Author Share Posted September 28, 2015 I grounded the lights directly to the battery. Link to comment Share on other sites More sharing options...
com3 Posted October 14, 2015 Share Posted October 14, 2015 sweet! i just got these same light for my FJ! thanks for the pics. i was trying to decide where/how to install, and i think yours is on the money. how are they holding up so far? Link to comment Share on other sites More sharing options...
zachd Posted October 15, 2015 Author Share Posted October 15, 2015 sweet! i just got these same light for my FJ! thanks for the pics. i was trying to decide where/how to install, and i think yours is on the money. how are they holding up so far?They're holding up fantastic. I feel much more confident knowing people see me a lot better now, both day and night. Link to comment Share on other sites More sharing options...
docsimple Posted November 14, 2015 Share Posted November 14, 2015 a word of warning. These are heavy and you need some strong brackets if you ride rough roads or aggressively: 2015 Red FJ 09 2013 WR250R - little boy blue - sold 2012 DL650 V Strom - sold 2007 FZ6 - sold 1986 FJ600 - sold Link to comment Share on other sites More sharing options...
zachd Posted November 15, 2015 Author Share Posted November 15, 2015 ^^^^Did you order the same bracket I listed above? These looks like it was bent on purpose? Link to comment Share on other sites More sharing options...
gabefzr6 Posted November 21, 2015 Share Posted November 21, 2015 Anytime you mount something in an unsprung location it will take a beating. If a suspended location is used then those brackets will probably be fine. 2008 Street Triple G 2015 FJ-09 Link to comment Share on other sites More sharing options...
goliath337 Posted May 13, 2016 Share Posted May 13, 2016 Many of the reviews on Amazon mentioned that the housing didn't hold up very well and they tended to leak or get moisture. Have any of you had this problem with these lights? TIA! Link to comment Share on other sites More sharing options...
