bgigharbor Posted July 29, 2016 Share Posted July 29, 2016 Anyone know if anyone makes a strap wrench small enough for the fj filter? None of mine go that small. Link to comment Share on other sites More sharing options...
caferacer Posted July 29, 2016 Share Posted July 29, 2016 You can buy smaller sized wrenches (http://www.acehardware.com/product/index.jsp?productId=1289585) but don't need to, I used one that fits a regular-sized car filter. I thought the same thing about the filter wrench I had at first, you just have to twist it past what you're used too, like wrap it around further past what you would on a large filter--hard to explain, but as you wrap it further it tightens and then you end up pulling the lever and when it evens out to a straight pull the filter loosens. Link to comment Share on other sites More sharing options...
JJM Posted July 29, 2016 Share Posted July 29, 2016 Lowes. Kobalt brand. Costs $7. Link to comment Share on other sites More sharing options...
Premium Member joeszup Posted July 30, 2016 Premium Member Share Posted July 30, 2016 I cut a piece of 1/4" leather into a 1" wide strip and then put that leather in between filter and wrench. Worked great. Link to comment Share on other sites More sharing options...
banjobart Posted August 5, 2016 Share Posted August 5, 2016 I use K&N filters with the 17mm hex nut on the end, then I can use the same 17mm socket on the oil drain plugs as the oil filters. This is much easier than a strap wrench. I use a Channellock pliers on other oil filters, you just toss it out so grip dents do not matter on the old oil filter. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 5, 2016 Premium Member Share Posted August 5, 2016 2nd on the K&N filters Link to comment Share on other sites More sharing options...
