cameron12x Posted February 13, 2015 Share Posted February 13, 2015 Has anyone found a good vendor for these? Preferably state-side? TIA. Link to comment Share on other sites More sharing options...
dv8ght Posted November 28, 2015 Share Posted November 28, 2015 Cycle Gear used to sell these. Protons are the brightest signals I have ever used. They are encased in acrylic and have a built in resistor. I found this site for them. http://www.hightechspeed.com/products/ProtonLights/ Link to comment Share on other sites More sharing options...
Premium Member jeff400650 Posted December 5, 2015 Premium Member Share Posted December 5, 2015 I'm not sure what you are asking. There are lots of led turn signals out there. I got these at Cycle Gear for the front and rear. I think they look and work great. They match the high tech looks of the bike and it's other lighting much better than the 1988 style incandescent stockers. Very bright too. http://www.cyclegear.com/SPEEDMETAL-LED-Angle-Light-Turn-Signals Pistons or pedals, 2 wheels are where it's at... Link to comment Share on other sites More sharing options...
badger Posted December 7, 2015 Share Posted December 7, 2015 I'm not sure what you are asking. There are lots of led turn signals out there. I got these at Cycle Gear for the front and rear. I think they look and work great. They match the high tech looks of the bike and it's other lighting much better than the 1988 style incandescent stockers. Very bright too. http://www.cyclegear.com/SPEEDMETAL-LED-Angle-Light-Turn-Signals For anyone that has changed out the incandescent turns signals to LEDs, did you have to add / change out the turn signal controller to make the LED turn signals blink at the correct rate? If so, what did you use? I have been looking at the Cyclegear / Speed Metal LEDs, but have not pulled the trigger yet because I don't know if I have to modify anything else to make the LEDs flash correctly. Link to comment Share on other sites More sharing options...
tommo Posted December 7, 2015 Share Posted December 7, 2015 I have R&G aero indicators on the front of my bike and Oxford Nano on the back. I replaced the flasher relay and mine all flash the correct rate. Link to comment Share on other sites More sharing options...
zachd Posted December 7, 2015 Share Posted December 7, 2015 I'm not sure what you are asking. There are lots of led turn signals out there. I got these at Cycle Gear for the front and rear. I think they look and work great. They match the high tech looks of the bike and it's other lighting much better than the 1988 style incandescent stockers. Very bright too. http://www.cyclegear.com/SPEEDMETAL-LED-Angle-Light-Turn-Signals For anyone that has changed out the incandescent turns signals to LEDs, did you have to add / change out the turn signal controller to make the LED turn signals blink at the correct rate? If so, what did you use? I have been looking at the Cyclegear / Speed Metal LEDs, but have not pulled the trigger yet because I don't know if I have to modify anything else to make the LEDs flash correctly. You'll need THIS bad boy and you're good to go. It's what I installed on mine. Plug and play, literally took 10 seconds. Link to comment Share on other sites More sharing options...
badger Posted December 8, 2015 Share Posted December 8, 2015 Outstanding! Thanks for the info/link. Link to comment Share on other sites More sharing options...
Premium Member jeff400650 Posted December 8, 2015 Premium Member Share Posted December 8, 2015 I just got one they had at Cycle Gear. I think it said for Honda or Kawi. Took a chance. Plugged right in. Woks great. Pistons or pedals, 2 wheels are where it's at... Link to comment Share on other sites More sharing options...
drewh108 Posted December 21, 2015 Share Posted December 21, 2015 I purchased some R&G aero led's for the front, and R&G minis for the rear. Very nice. Also got the resistors in 21 ohms. Having some flashing issues with all four installed, too fast. Tried plugging in the stock rears to test, and all is well again. May have too much resistance now? Will be looking for a flasher to fix this issue. Link to comment Share on other sites More sharing options...
Premium Member clint Posted December 21, 2015 Premium Member Share Posted December 21, 2015 I purchased some R&G aero led's for the front, and R&G minis for the rear. Very nice. Also got the resistors in 21 ohms. Having some flashing issues with all four installed, too fast. Tried plugging in the stock rears to test, and all is well again. May have too much resistance now? Will be looking for a flasher to fix this issue.Get this flasher relay. It's a perfect plug and play replacement for OEM. Even fits in the OEM mount. I've had mine installed for months...perfect! Adjustable flash rate too. TST Industries LED Flasher Relay Piedmont of NC '15 FJ-09 '94 GTS-1000 Link to comment Share on other sites More sharing options...
drewh108 Posted December 21, 2015 Share Posted December 21, 2015 Thanks for the link. Cheers! Link to comment Share on other sites More sharing options...
Guest Posted December 21, 2015 Share Posted December 21, 2015 R&G Micro Indicators from Twisted Throttle. Great product and Twisted Throttle is the best to deal with. Link to comment Share on other sites More sharing options...
maxxam Posted March 14, 2016 Share Posted March 14, 2016 I purchased some R&G aero led's for the front, and R&G minis for the rear. Very nice. Also got the resistors in 21 ohms. Having some flashing issues with all four installed, too fast. Tried plugging in the stock rears to test, and all is well again. May have too much resistance now? Will be looking for a flasher to fix this issue.Get this flasher relay. It's a perfect plug and play replacement for OEM. Even fits in the OEM mount. I've had mine installed for months...perfect! Adjustable flash rate too. TST Industries LED Flasher Relay Just to confirm this relay did the trick when using LED turn signals in the front AND rear. Thanks! Link to comment Share on other sites More sharing options...
hammer Posted March 14, 2016 Share Posted March 14, 2016 http://www.motodynamic.com/catalogsearch/advanced/result/?name=&description=&short_description=&sku=&price%5Bfrom%5D=&price%5Bto%5D=&make=Yamaha&v_model=FJ-09&year=2015 Have these waiting for a dry day to install. Cheers! Link to comment Share on other sites More sharing options...
zachd Posted March 15, 2016 Share Posted March 15, 2016 Just to confirm this relay did the trick when using LED turn signals in the front AND rear. Thanks! Use this, it worked perfect for me, and is even cheaper: http://www.amazon.com/gp/product/B00RM26LXO?psc=1&redirect=true&ref_=oh_aui_detailpage_o09_s00 Link to comment Share on other sites More sharing options...
