jdavis Posted June 12, 2018 Share Posted June 12, 2018 Fitted Driving Lights today, powered from the Battery (10amp fuse), switched via the Y/B wire from the headlight controller under the headlights. Works from the hi beam. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 12, 2018 Supporting Member Share Posted June 12, 2018 Yikes, angled directly at eye level into oncoming traffic. I don’t foresee that causing any accidents.... ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
jonno12345 Posted June 12, 2018 Share Posted June 12, 2018 Yikes, angled directly at eye level into oncoming traffic. I don’t foresee that causing any accidents.... He said it works from full beam so I suspect it's only on when the road is clear Link to comment Share on other sites More sharing options...
jdavis Posted June 13, 2018 Author Share Posted June 13, 2018 Only used with high beam. Not an urban use item. Link to comment Share on other sites More sharing options...
