pilninggas Posted December 9, 2020 Share Posted December 9, 2020 (edited) Back in 2009 I had a new XJ6/FZ6R. It suffered from the same issue, shedding o-rings. I cant believe this is still an issue. A number of other people with XJs also suffered the same problem. Yamaha wouldn't honour it back then. I assume Yam still use DID's OEM chains. Which - unlike DID's aftermarket chains - are utter junk. In terms of the inconsistent mileage from people's chains, id say this is variation within the DID supply chain - quality variation between factories. Yamaha should have sort these quality issues by now. Edited December 9, 2020 by pilninggas Link to comment Share on other sites More sharing options...
rockinsv Posted December 10, 2020 Share Posted December 10, 2020 7 hours ago, metallion said: I used to use that Dupont chain saver back when i had my Triumph Tiger 1050 because that bike had such a short chain guard and threw regular lube everywhere. I never thought it lubed all that well to me so i stopped using it. Seems like you had great luck with it though! I ran my stock FZ1 chain up to a little over 30,000 miles using that lube and it could've went further, but I replaced for peace of mind. Link to comment Share on other sites More sharing options...
rockinsv Posted December 10, 2020 Share Posted December 10, 2020 One thing with adding to this is how tight the chain comes on this bike. It can't be good for it being that tight. What I find odd is at my local dealer you can check the 900's and they're tight as hell and then check the 700's and they are more normal. Link to comment Share on other sites More sharing options...
FrankQC Posted February 13, 2021 Share Posted February 13, 2021 On 12/8/2020 at 7:39 PM, silverninja said: All very interesting. The O-rings on my chain (2016 FJ) were disintegrating at 14K miles; that is the shortest life I've ever had on a modern motorcycle. I am religious about cleaning and lubing. Replaced the chain with EK brand. Same here, but way sooner. My 2016 FJ began shedding O-rings at about 8000 miles on the OEM chain. I replaced it a while ago with a DID 525 VX3 along with new JT sprockets, never looked back. 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted February 13, 2021 Supporting Member Share Posted February 13, 2021 I bought my FJ used with ~12,000 KM (~7500 miles). I put about 1000 km on it and several o-rings failed and many links became stiff. Since replacing chain & sprockets (with a bit more slack as advised on this forum) I've more than doubled the odo and the (no longer) new chain seems to be holding up just fine. With semi-regular clean & gear oil lube. 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
