Fortitudinous Posted May 11, 2021 Share Posted May 11, 2021 Hi, after doing some maintenance to my bike and had assembled everything, I discovered a small white nylon flanged shoulder washer on the floor, which must have detached itself from an unknown part. Does anyone know what this does and where it goes to? Many thanks in advance. FYi - outer diameter is 20mm, inner dia 8 mm, 5 mm thick (see photos). I removed and reinstalled the windshield, the side fairings and the battery. Link to comment Share on other sites More sharing options...
Xstoff Posted May 11, 2021 Share Posted May 11, 2021 Found one of those while flushing the coolant reservoir Link to comment Share on other sites More sharing options...
Fortitudinous Posted May 11, 2021 Author Share Posted May 11, 2021 Hi Xstoff, don’t think it came from there, the coolant one is longer, probably different size too. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 11, 2021 Supporting Member Share Posted May 11, 2021 I believe there is one like that on each side of the windscreen height adjustment slide. 1 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted May 11, 2021 Premium Member Share Posted May 11, 2021 It is from the windscreen adjusters. "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted May 11, 2021 Premium Member Share Posted May 11, 2021 If you look at the left side of this picture you will see two small white nylon washers. They take up space and allow for smooth-ish adjustment of the windscreen 1 1 "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
Premium Member fddriver2 Posted May 11, 2021 Premium Member Share Posted May 11, 2021 Number 9 here. YAMAHA GENUINE PARTS' 2015 Yamaha FJ-09 | WINDSHIELD Parts List (onlinemicrofiche.com) Edited to show the proper microfiche 1 "It doesn't matter who walks in, you know the joke is still the same" Ft. Lauderdale, Florida. USA Link to comment Share on other sites More sharing options...
Fortitudinous Posted May 11, 2021 Author Share Posted May 11, 2021 (edited) Thanks a million, fddriver2 and betoney! That was my suspicion as well but can’t be sure. Also looked at the parts diagram a thousand times but couldn’t locate it! Edited May 11, 2021 by Fortitudinous Forgot to thank betoney! 2 Link to comment Share on other sites More sharing options...
