PhotoAl Posted June 14, 2021 Share Posted June 14, 2021 I'm not too surprised at 12,000 miles on a liter bike if it's ridden hard. Believe they are running 525s, used to be 530 but to lower chain mass and overall weight they've gone to the smaller chain. 525 is what the Tracer GT uses and has less HP. He probably replaces chains before they get in too bad a condition - I've seen chains fail on the track and at best it an uncomfortable situation. Imagine planning to use power to stand the bike up from corner apex and boom, no power no drive and you coast to a stop. Much worse stuff can happen. Link to comment Share on other sites More sharing options...
Ride365 Posted June 14, 2021 Share Posted June 14, 2021 3 hours ago, Mattf said: That's amazing mileage out of a chain & Sprockets. What size motor? I typically go about 12,000 miles on a chain. That's on mostly Liter Bikes.I ride pretty hard. Don't like to push wear componets to the last bits. Sitting on the side of the road is not a good time! Gets that kind of mileage on both 650's and liter bikes "Suzuki V-Stroms". Link to comment Share on other sites More sharing options...
TomTracer Posted June 14, 2021 Share Posted June 14, 2021 1 hour ago, Ride365 said: Gets that kind of mileage on both 650's and liter bikes "Suzuki V-Stroms". I tode the geck out of 2 DL650's and got over 20,000 out of every chain in over combined 115,000 miles. 12000 is not good! 5 hours ago, Mattf said: That's amazing mileage out of a chain & Sprockets. What size motor? I typically go about 12,000 miles on a chain. That's on mostly Liter Bikes.I ride pretty hard. Don't like to push wear componets to the last bits. Sitting on the side of the road is not a good time! What kind of chain are you using!!? Ate you tunning it looser rather than tight, and do you check you alignment? Thats ridiculously short chain life if mainly road mileage. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted June 14, 2021 Premium Member Share Posted June 14, 2021 Another chain thread Ok 520 premium chain on a 102 hp / max 70#' Expect 18000 +- Link to comment Share on other sites More sharing options...
Wintersdark Posted June 14, 2021 Share Posted June 14, 2021 On 6/13/2021 at 8:46 AM, Ride365 said: CLEANING chains causes the most issues, at least in terms of how some do it with solvents and brushes. And is ultimately unnecessary in most cases too. I mean, it's nice to have a clean shiny chain, but unless it's caked in mud and sand just ensuring it's lubed is good. 2 Link to comment Share on other sites More sharing options...
Rodman Posted July 2, 2021 Share Posted July 2, 2021 Klotz KLR is the best chain lube I've ever used. Very clean. Doesn't sling. Link to comment Share on other sites More sharing options...
