SlipperyNiblets Posted December 21, 2022 Author Share Posted December 21, 2022 @skipperT I can wiggle the exhaust side of the chain a little bit, but cannot get the screwdriver blade underneath the chain. As it sits now the intake side of the chain does not move at all. How tight should I set my manual tensioner? Link to comment Share on other sites More sharing options...
skipperT Posted December 22, 2022 Share Posted December 22, 2022 23 hours ago, estell said: Skip, can you clarify how close is a tiny bit? Is the picture above a tiny bit, or is it off by one tooth? I recall that one of my cam marks was off by about as much as the picture above. I thought that was as close as I could get. If it was off by one tooth, then would the mark be off by much more than that? Very tough question to answer based on the pic above, which is why I suggested to @SlipperyNiblets that the chain might not be smoothly interfaced on the crank gear, or that the crank was off by a C.H. Camchain wear and how perfect the marks were aligned when it was taken apart are other factors as well. Its honestly best to snap a pic BEFORE it comes apart IMHO, you really can’t be sure if it’s lined up until the tensioner is installed and the engine is rotated a couple times and then set to the K removal mark. At which point if you rotate one “click” in either direction, would your mark be closer or further away to being dead nuts on if that “click” distance were 1 tooth on the cam gears? It’s tough to answer and I really can’t give you a definite. Next time I have an cp3 apart, I’ll snap a pic in various positions to clarify. The only way to really verify now is to pull the valve cover and check your timing. if it runs as well as it did before you adjusted anything, it’s probably ok. -Skip 1 Link to comment Share on other sites More sharing options...
skipperT Posted December 22, 2022 Share Posted December 22, 2022 10 hours ago, SlipperyNiblets said: @skipperT I can wiggle the exhaust side of the chain a little bit, but cannot get the screwdriver blade underneath the chain. As it sits now the intake side of the chain does not move at all. How tight should I set my manual tensioner? That’s fairly typical on this engine. I don’t know how to set the manual tensioners as I don’t really believe in them and don’t have the instructions written down anywhere. I’m sure Ape has them on their website, or another member will post back here. I do recall that if they are a hair tight you’ll never really know except by the amount of material gets worn from the timing chain guides and if too loose, they are a bit loud. what I would do is set as tight as you can by hand, and then go a tad more (1/4 turn? ). Have someone slowly turn the engine over while you watch the cam chain on the intake side as it falls off the sprocket toward the tensioner. There WILL be a point where the tension loosens slightly. When you find that point, loosen the tensioner locknut, and screw in the adjuster by hand again till it touches the chain (it will be harder to turn by hand is the clue that it has touched the guide) then snug it again 1/8- 1/4 turn, and snug the locknut. Start the engine in that position and tighten it a bit more (after it’s warmed?) if it’s loud. If it‘s quiet, forget it and see how it is a full op temp coming down in engine speed after a quick rev to 6 or 7k or so. if it’s loose, it may “whir” or “clack” slightly esp on the excel. Bueller with a manual tensioner? Please chime in. -S 1 Link to comment Share on other sites More sharing options...
skipperT Posted December 22, 2022 Share Posted December 22, 2022 Oh and use a sharpie to mark the flats of the nut /bolt so you know exactly where you started and how many turns you went, etc. -S 1 1 Link to comment Share on other sites More sharing options...
OZVFR Posted December 22, 2022 Share Posted December 22, 2022 https://aperaceparts.com/tech/tensioners.html 1 Link to comment Share on other sites More sharing options...
SlipperyNiblets Posted December 22, 2022 Author Share Posted December 22, 2022 11 hours ago, OZVFR said: https://aperaceparts.com/tech/tensioners.html the guy in the write up here has the same PFP as you, I appreciate the help. https://www.fz09.org/threads/how-to-install-ape-cct.3595/ Now if that gasket would only get here I can hit the starter and pray. 1 Link to comment Share on other sites More sharing options...
OZVFR Posted December 22, 2022 Share Posted December 22, 2022 1 hour ago, SlipperyNiblets said: the guy in the write up here has the same PFP as you, I appreciate the help. https://www.fz09.org/threads/how-to-install-ape-cct.3595/ Now if that gasket would only get here I can hit the starter and pray. What the hell, I’ve had my identity stolen. 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted December 22, 2022 Premium Member Share Posted December 22, 2022 I actually warm up the engine and back it off a little and set the tension in while it's running so the rattle just stops. Then snug it up the nut while holding the adjuster... 2 Link to comment Share on other sites More sharing options...
SlipperyNiblets Posted February 9, 2023 Author Share Posted February 9, 2023 It's been a while but I got the bike back together and along with a twdw tune and akrapovic exhaust, it runs perfectly, thanks for all your help. Now to wait for spring.... 1 Link to comment Share on other sites More sharing options...
ItsTracerTime Posted July 1, 2023 Share Posted July 1, 2023 So for everyone, myself included, who checked them pre-24k...I did mine at 16k and they were slightly out. I am now at 24k, do I need to check them again or do I base the 24k interval off of my last 16k check, and recheck at 30k? Link to comment Share on other sites More sharing options...
PhotoAl Posted July 2, 2023 Share Posted July 2, 2023 I checked mine at 18,000 if memory is correct. Currently at 28,000 and just going to sell the bike LOL! Seriously have thought about that and was going to check them after next long trip which would be about 36,000. Don't have a sense of urgency but would probably make the 2nd check early as well - not wait 24 thousand after the 1st check. My impression is the valves tend to go out of adjustment pretty early and then do not change much. Link to comment Share on other sites More sharing options...
CPD419 Posted July 3, 2023 Share Posted July 3, 2023 Yamaha has came a long ways with their valves when I started riding street bikes in the 80’s they were notorious for needing adjusted. The viragos were horrible and I had a 400 special that needed adjusted seemed like every season. Link to comment Share on other sites More sharing options...
