deersSlayer Posted June 8, 2016 Share Posted June 8, 2016 Anybody have a front wheel stand that works well to lift the front end? I could use a lift underneath the header, but that can't be very good for the header! FJ-09, 690 Enduro R. Back Roads. Period. Link to comment Share on other sites More sharing options...
bruceintucson Posted June 8, 2016 Share Posted June 8, 2016 Anybody have a front wheel stand that works well to lift the front end? I could use a lift underneath the header, but that can't be very good for the header! Scissor jack and a piece of wood between it and the headers. Won't hurt them, you're not lifting much weight. 1 Link to comment Share on other sites More sharing options...
badger Posted June 8, 2016 Share Posted June 8, 2016 I used my Pitbull triple tree stand and R6 pin for it; worked perfectly. 1 Link to comment Share on other sites More sharing options...
rocky5000100 Posted June 8, 2016 Share Posted June 8, 2016 Yes Pit Bull triple tree lift if you're going to be using it regularly. The cheaper brands also work, but tend to fail much sooner than Pit Bull products. Browse your local craigslist, and you'll eventually find someone selling a Pit Bull stand cheaper than retail, and it'll continue to last years and years. Link to comment Share on other sites More sharing options...
xlxr Posted June 8, 2016 Share Posted June 8, 2016 I built an self supporting A frame out of 2X4's and use a motorcycle strap around the handle bars to hold the front end up when removing front wheel/suspension. Use center stand for rear. When I'm done, I unscrew the A frame and stack the parts in a corner of the garage until next time it is needed. Link to comment Share on other sites More sharing options...
blindjoebeck Posted June 10, 2016 Share Posted June 10, 2016 I use a standard Pit Bull front stand that lifts from the bottom of the forks. I remove the ABS sensor before fitting the stand. I would like a front stand that lifts from the triple tree, but when I need to remove the forks, I either prop up the headers or hang the front of the bike from the overhead joists in the garage. -- John Link to comment Share on other sites More sharing options...
bikefanatic Posted June 10, 2016 Share Posted June 10, 2016 I tried using the Pitbull stand that i have used on my last 4 bikes. One of my old pins worked in diameter size, but was hitting the horn. I need to get the right pin that has the correct offset, if that makes sense. Link to comment Share on other sites More sharing options...
deersSlayer Posted June 12, 2016 Author Share Posted June 12, 2016 I tried using the Pitbull stand that i have used on my last 4 bikes. One of my old pins worked in diameter size, but was hitting the horn. I need to get the right pin that has the correct offset, if that makes sense.Pitbull staff said the FJ-09 needs their # 4 pin. Not sure if it has correct offset, or the horn needs removal??? FJ-09, 690 Enduro R. Back Roads. Period. Link to comment Share on other sites More sharing options...
bikefanatic Posted June 17, 2016 Share Posted June 17, 2016 Pin #4 has a collar which hopefully provides the necessary offset so the horn doesn't get pinched. Looks good from the picture. Link to comment Share on other sites More sharing options...
pattonme Posted December 5, 2016 Share Posted December 5, 2016 The cheaper stands may not be tall enough for the FJ. In which case a length of 2x4 under the wheels suffices to provide the needed extra height. Link to comment Share on other sites More sharing options...
Premium Member jgalloway Posted December 5, 2016 Premium Member Share Posted December 5, 2016 Has anyone used the Venom brand stand? The stand comes with an 18mm pin, but here's a 20mm pin available for use with the FZ/FJ, sold separately. The Trex and Pitbull stands seem awfully pricy for occasional use. I have the bike all prepped to remove the wheel and the suspension, just looking to get a stand.... Venom looks tempting.I have a Venom stand. It works for super sports (I've used it on an R1 and a SV1000) but it wasn't tall enough for my FZ1. I just used a piece of 4X6 under each side to make it tall enough, and it worked like a charm. I'm assuming I'll have to use those with the FJ as well. I'll find out in a couple of weeks when I remove the forks and send them to Forks by Matt. If I was a racer and needed to use it daily, or even weekly, I'd probably get a Pitbull so that I didn't have to mess with the pieces of wood. If you are only going to use it once or twice per year, the Venom is all you need. Link to comment Share on other sites More sharing options...
pattonme Posted December 5, 2016 Share Posted December 5, 2016 Also there's this: http://www.carpimoto.it/en-US/32027_CM03SM-Front-Wheel-Fork-Stand-CM03SM.htm Not sure how well it works. A lot depends on the throw of that lever. Link to comment Share on other sites More sharing options...
Premium Member exploring/carolina Posted January 16, 2017 Premium Member Share Posted January 16, 2017 Have used a set of GPI paddock stands on sport and sport touring bikes. Just bought the FJ09 last Friday, so tried the stands out on the FJ tonight. Used a 20MM pin on the FJ triple tree bearing stem and the stands worked fine lifting both tires off the ground at the same time. The horizontal pin that secures the vertical 20MM pin contacted the horn, so left the pin out that secures the 20MM pin and the front stand worked fine. The 20MM pin has a large enough OD to fit the stand without slipping through the smaller ID hole in the stand. Front adjustable height paddock stand with horizontal pin installed securing vertical 20mm pin. In this photo the 20MM larger step cannot be seen that prevents the pin from slipping through the stand hole with the horizontal pin removed. Paddock stand with FJ front wheel in the air, without horizontal pin securing 20MM pin. If the horizontal pin is left installed, it will contact the horn: Used the rear stand without spool lift: Link to comment Share on other sites More sharing options...
dundee Posted January 22, 2020 Share Posted January 22, 2020 (edited) Can you repost photos as I'm interested in the GPI triple tree stand and would like to see that it can lift the bike without using blocks of wood. The pin is 19 mm (loose fit) or 20 mm (tight fit). If the group knows which brands of triple tree stands will work with the Tracer without blocks of wood that would be appreciated. Edited January 22, 2020 by dundee Link to comment Share on other sites More sharing options...
jdavis Posted January 23, 2020 Share Posted January 23, 2020 (edited) 14 hours ago, dundee said: Can you repost photos @dundeeMost of the old pics went with the site upgrade a while back. Dont think the poster is still current either. Edited January 23, 2020 by jdavis Link to comment Share on other sites More sharing options...
