agunslinger Posted September 12, 2017 Share Posted September 12, 2017 If I purchase the CustomLED integrated tailight and tail tidy, and dont use the OEM tail turn signal lights, whats done with the two OEM turn signal wires? Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted September 12, 2017 Premium Member Share Posted September 12, 2017 If I purchase the CustomLED integrated tailight and tail tidy, and dont use the OEM tail turn signal lights, whats done with the two OEM turn signal wires? If that's the same one that I have ( it's been a 1.5 years since I put it on) the stock wires are used for the turn signal function in the tail light. Let’s go Brandon Link to comment Share on other sites More sharing options...
agunslinger Posted September 12, 2017 Author Share Posted September 12, 2017 Ahh, I guess that makes complete sense. Almost a stupid question. ;^) Thanks! Link to comment Share on other sites More sharing options...
prn Posted September 19, 2017 Share Posted September 19, 2017 Ahh, I guess that makes complete sense. Almost a stupid question. ;^) Thanks! Just FYI - if you are going to remove OEM turn signals then you need ELFR-1 flasher relay. This relay will replace the OEM flasher relay and provide for the normal blink rate after removing the OEM signals. If you keep the factory relay installed, it will blink fast in an attempt to tell you that you have an incandescent light bulb burned out. Link to comment Share on other sites More sharing options...
thetruck454 Posted September 20, 2017 Share Posted September 20, 2017 Ahh, I guess that makes complete sense. Almost a stupid question. ;^) Thanks! Just FYI - if you are going to remove OEM turn signals then you need ELFR-1 flasher relay. This relay will replace the OEM flasher relay and provide for the normal blink rate after removing the OEM signals. If you keep the factory relay installed, it will blink fast in an attempt to tell you that you have an incandescent light bulb burned out.I second that. I added the relay and all is good in the world of blinking rates '15 FJ-09 with an aftermarket parts addiction Link to comment Share on other sites More sharing options...
sellersfj09 Posted February 11, 2018 Share Posted February 11, 2018 I prefer the fast blink, like hey you inattentive drivers I am right here, turning. Link to comment Share on other sites More sharing options...
bikerdup Posted November 20, 2018 Share Posted November 20, 2018 Where does the turn signal relay live on this bike? Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted November 20, 2018 Supporting Member Share Posted November 20, 2018 Where does the turn signal relay live on this bike? It’s under the rider’s portion of the seat, on the right side by the battery box... Link to comment Share on other sites More sharing options...
zachd Posted November 20, 2018 Share Posted November 20, 2018 Where does the turn signal relay live on this bike?tucked nicely in between the frame and battery on the right side of the bike Link to comment Share on other sites More sharing options...
