  • Who's Online   0 Members, 0 Anonymous, 12 Guests (See full list)
Softer rear spring
ledruide
@pattonme
Hi,
      I'm looking for a softer rear shock spring for my 2017 FJ09, I weight 130 ( 56 kg)  and the original spring is pretty stiff
Any recommandations?
Thanks
If you contact any competent suspension shop, they should be able to recommend spring rates (front and rear) for your weight - with riding gear. At a bare minimum, get correct rate springs and set your rider sag.
Contact @pattonme for correct spring rate and pricing.
Your weight is in the sweet spot for the OEM springs... you can adjust the rear shock 2 ways by either the preload or adjusting the compression needle (?)...
The OEM shock doesn't have compression adjustability, preload and rebound clicker only.
I don't agree with you, preload and rebound setting are at the minimum, with a passenger on the bike total weight is around 270 and the ride is much better, after 15000 km. with this bike I can say the spring is pretty stiff
How can I contact him, don't see a way to send a message to pattonme
Thanks
I'm ~160 and the stock springs are okay for me. Shave 30 lbs, and yea, I could see needing lighter springs.
To message pattonme:
Click on his blue name, that will take you to his profile.
Look in the right hand corner above all of his follower's profile pictures
There's a "Send Message" button.
Cheers
'15 FJ09
Cheers
Thanks, but there is only a FOLLOW button , no send message button??
@pattonme
Hi,
Thanks
The FZ 09's were supposedly undersprung.  You might be able to find a take off FZ 09 shock for cheap.  Damping won't be improved.
@pattonme
It could be an interesting option, thanks for the information
You might need a minimum post count to send private messages actually. Would explain whats up.
That's make sense,  11 messages and I have now the message button, so maybe 10 is the minimum !
Thanks
alright I'm here! 130lb you want a 90 or perhaps 85N/mm spring. The problem is the spring length is non-standard so you'll need a custom spacer. That won't fix the (especially) comp or rebound damping issues though. The ZX6 shocks that fit run a 90N/mm spring by default and can run any standard spring. The damping is marginally better but the unwelcome aspect (?) is that the shock is longer which will raise your saddle height.
Tanks for the input pattonme, As they say, it's all about compromise !!
