cmyipp2 Posted October 17, 2015 Share Posted October 17, 2015 Link to comment Share on other sites More sharing options...
Premium Member paladin Posted April 2, 2016 Premium Member Share Posted April 2, 2016 I installed the same riser but it has an offset to bring the bar about 1 1/4" closer. The cables were fine, but the wires and brake were tight. I moved 2 of the cable ties on the bars to get enough slack. I also rotated the brake line a little get some slack there. I have only ridden around town but steering seems to be easier and more responsive. I now have a little bend in the elbow, I hope to reduce hand and wrist pain. I got mine at Revzilla, $103. Link to comment Share on other sites More sharing options...
Premium Member estell Posted April 21, 2016 Premium Member Share Posted April 21, 2016 yes, fit perfectly Hi cmyipp2: I see you removed the fairings...was that part of this job by any chance? ...so it's fairly simple to add the risers and you say that no cable adjustment is needed? I see that the brake line on my FJ-09 does not have hardly any slack. Clutch seems to have ~ 1"...did you have to remove any clamps or T's to get more additional cable slack? Does the cables pull tight when you turn the handlebars full/right? Appreciate your responses...thanks much - Joel I added these SW Motech risers. I didn't have to change any cables, but I did have to reroute the wires and cables to go in front of the bar risers on their way to the tree instead of routing behind the risers as they were originally. That allowed enough slack in the cables to compensate for the extra length in the riser. I think it has unloaded a little weight off my hands to lessen the numb-thumb effect that I get on long rides. Then I expect the cruise control will eliminate the remainder of the numbness. 2015 red FJ-09: Cal Sci screen, Sargent seat, ECU flash, slider combo, cruise, Rizoma bars, Matts forks, JRi shock, slipper clutch Link to comment Share on other sites More sharing options...
fitrider82 Posted April 22, 2016 Share Posted April 22, 2016 Gilles Tooling does some really nice stuff. What is the advantage of spending $150 on those? '15 FJ-09 - Candy Red. Mods: Cruizin cruise control, Givi D2122S WS & crash bars. Rivco anti-vibration highway pegs. Yamaha rear rack & softbags. RAM mount X grip at handlebar bolts. Shorty levers. Tail assembly shortened. FZ6 rubber pegs. '05 Honda CRF450r '77 Honda CB550f Super Sport Link to comment Share on other sites More sharing options...
g8r Posted May 22, 2016 Share Posted May 22, 2016 I had the 2" Rox Risers installed and the reach is much more comfortable. The cables are very tight and I would like to get longer replacements. Has anyone changed them and if so, who was the supplier? Link to comment Share on other sites More sharing options...
tyler1 Posted March 13, 2017 Share Posted March 13, 2017 Any chance that these are available in the US? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 14, 2017 Premium Member Share Posted March 14, 2017 I just don't get how someone 6'-1" or anyone for that matter over 5'-8" really feels they need the bars higher and more rearward from stock unless you are totally used to cruisers and choppers. Whereas the stock bars are fairly comfortable the angle they place your wrists is unnatural and almost painful. Furthermore, being positioned that high and rearward to me is not conducive to feeling the Cg of the bike and what the front end is doing. That is why I installed almost 1.5" lower bars with more sweep and finally found the sense of feel and control IMO needed to ride at even a moderate pace and that gets better the faster you ride. Link to comment Share on other sites More sharing options...
adjuster Posted March 15, 2017 Share Posted March 15, 2017 Great thing about bikes, they can fit everyone. Link to comment Share on other sites More sharing options...
desertfjr Posted March 16, 2017 Share Posted March 16, 2017 I had the 2" Rox Risers installed and the reach is much more comfortable. The cables are very tight and I would like to get longer replacements. Has anyone changed them and if so, who was the supplier?I sent a set of stock cables, clutch and throttle, off to MotionPro to have set of extended cables built, 2 clutch and one throttle. I will try to remember to post up all the info on the sheet when they return them to me with the extended cables. I am being a tad conservative and adding 3 inches to each for my 2 up Rox. I want to reroute the clutch to a larger radius and eliminate the "hotspot". Adding a Scootworks brake line extender. Should have all the tension off everything. Link to comment Share on other sites More sharing options...
desertfjr Posted March 23, 2017 Share Posted March 23, 2017 Talked with MotionPro. They have everything they need for extended FJ cables. You can just call and order whatever extended length you need. Link to comment Share on other sites More sharing options...
dbeau Posted June 13, 2018 Share Posted June 13, 2018 Surely they changed something with the 2017 model cables/wires. Just tried installing the Rox 2" riser and it's not even close. I'd have to take the tank off to even see if it's possible to get enough slack for the throttle... Anyone have experience with risers on a 2017? Edit: Nevermind, just found another thread where everyone talks about pretty involved cable re-routing and longer cables and such. Seller told me he didn't have to mod anything... Link to comment Share on other sites More sharing options...
