mike Posted November 16, 2021 Share Posted November 16, 2021 The valves on my bike were checked and adjusted at 18,000 miles. As with most bikes, all of the exhaust valves were tight and had to be shimmed. I am pushing 32,000 miles now and am wondering how many of you had to adjust the valves on the second round? Do they hold their clearance better after the first adjustment or do they continue to wear at the same rate? Thanks in advance Mike 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 16, 2021 Supporting Member Share Posted November 16, 2021 42 minutes ago, mike said: The valves on my bike were checked and adjusted at 18,000 miles. As with most bikes, all of the exhaust valves were tight and had to be shimmed. I am pushing 32,000 miles now and am wondering how many of you had to adjust the valves on the second round? Do they hold their clearance better after the first adjustment or do they continue to wear at the same rate? Thanks in advance Mike Mine were tight on the first inspection (@23k) but within spec on the 2nd (@44k) and 3rd (@64k) inspection. 1 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted November 16, 2021 Supporting Member Share Posted November 16, 2021 I will be able to report on the second check soon enough. All exhaust were tight on first check at 23K miles, with evidence of tracking on the heel of one lobe. I think most reports of the second and subsequent checks were encouraging. Link to comment Share on other sites More sharing options...
mike Posted November 16, 2021 Author Share Posted November 16, 2021 Thanks guys, that sets my mind at ease a bit. Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 16, 2021 Premium Member Share Posted November 16, 2021 115K miles. Checked around every 25K. Never needed adjustment. 4 Let’s go Brandon Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted November 16, 2021 Premium Member Share Posted November 16, 2021 Can you hear them? I could hear them at 20k. They were all tight. I'm at 35k miles and I can't hear them yet. So long as they don't make noise, I'll check them again at 40k miles probably in the late spring. (This is not the most scientific method of checking, but this motor has very distinct sounds that make it crazy making and/or a little easier to troubleshoot) Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 17, 2021 Premium Member Share Posted November 17, 2021 No, not over the sound of the noisy clutch… 5 Let’s go Brandon Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted November 17, 2021 Premium Member Share Posted November 17, 2021 First major service exhaust valves were tight. Bike goes in for service Thursday. Runs good. 51k plus. We'll see. Link to comment Share on other sites More sharing options...
OZVFR Posted November 17, 2021 Share Posted November 17, 2021 1 hour ago, micah2074 said: No, not over the sound of the noisy clutch… and the gear whine. Link to comment Share on other sites More sharing options...
CRFan250 Posted November 17, 2021 Share Posted November 17, 2021 17 hours ago, 1moreroad said: Can you hear them? I could hear them at 20k. They were all tight. I'm at 35k miles and I can't hear them yet. So long as they don't make noise, I'll check them again at 40k miles probably in the late spring. (This is not the most scientific method of checking, but this motor has very distinct sounds that make it crazy making and/or a little easier to troubleshoot) You will never "hear" a tight valve.....the gap closes and it actually gets quieter. You may hear a loose valve but the concept of hearing a tight valve is wrong in every sense. 6 Link to comment Share on other sites More sharing options...
skipperT Posted November 17, 2021 Share Posted November 17, 2021 7 hours ago, CRFan250 said: You will never "hear" a tight valve.....the gap closes and it actually gets quieter. You may hear a loose valve but the concept of hearing a tight valve is wrong in every sense. For the most part, yes… except when they get so tight they are stuck open and will have a slight “whirling” sound at higher RPM’s. Usually that’s on a multi valve head with several tight-and-stuck-open ex valves. Smaller engines won’t even start. -Skip 1 Link to comment Share on other sites More sharing options...
