stringman Posted June 6, 2022 Share Posted June 6, 2022 Hi all I have swapped out a Mto09 tracer 17reg for a 19 reg GT I was going to fit my TN2122 bars on the bike but see that Givi list a different model (TN2139) I would have thought the old ones would fit. But before I remove the fitted crash bungs to see I wondered if any of you intelligent lot knew fro sure either way? TIA Link to comment Share on other sites More sharing options...
Grumpy Goat Posted June 6, 2022 Share Posted June 6, 2022 2 hours ago, stringman said: Hi all I have swapped out a Mto09 tracer 17reg for a 19 reg GT I was going to fit my TN2122 bars on the bike but see that Givi list a different model (TN2139) I would have thought the old ones would fit. But before I remove the fitted crash bungs to see I wondered if any of you intelligent lot knew fro sure either way? TIA Looking at the PDFs on the Givi website for both I see that the: TN2122 - KN2122 is for YAMAHA MT-09 TRACER (2015) TN2139 - KN2139 is for YAMAHA TRACER 900/ TRACER 900 GT (2018) I have the latter fitted on my bike. I don't have a definitiive answer on whether the TN2122 would fit on the GT but I suspect that the mounting points may be different, since it makes no sense to create a separate product if the existing one would work. 1 Regards, Grumpy Goat | 2019 Yamaha Tracer 900 GT & 2016 BMW R1200RS Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted June 7, 2022 Supporting Member Share Posted June 7, 2022 There is a thread on the Niken side of the forum where Givi bars where adjusted to fit the Niken which may have similar dimensions to the 2019 GT? You could compare measurements. Link to comment Share on other sites More sharing options...
