etex Posted June 24, 2023 Share Posted June 24, 2023 Has anyone installed a Speedohealer on a 2021 or 22 Tracer 9 GT? If so, did you have any problems or issues with the install? Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted June 25, 2023 Supporting Member Share Posted June 25, 2023 Installed one on my DL1000. Great product. Can't speak for your bike, but Speedohealer would be my go-to if I needed to calibrate my speedo. 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / GIVI DS2122S windscreen / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Ride365 Posted June 25, 2023 Share Posted June 25, 2023 (edited) The speedo is barely off on these bikes, most I have ever seen per my GPS is 2 MPH displayed over actual. Edited June 25, 2023 by Ride365 1 Link to comment Share on other sites More sharing options...
Grumpy Goat Posted June 25, 2023 Share Posted June 25, 2023 24 minutes ago, Ride365 said: The speedo is barely off on these bikes, most I have ever seen per my GPS is 2 MPH displayed over actual. Exactly same here. Wish I could say the same about my other bike ... more like 5 mph max on that one. 😏 Regards, Grumpy Goat | 2019 Yamaha Tracer 900 GT & 2016 BMW R1200RS Link to comment Share on other sites More sharing options...
Heli ATP Posted June 25, 2023 Share Posted June 25, 2023 According to my GPS the Niken reads about 2mph high also. I try not to notice as it's help a little with the speed limit, if you know what I mean. 😉 Link to comment Share on other sites More sharing options...
etex Posted June 25, 2023 Author Share Posted June 25, 2023 (edited) My bike reads about 2 - 3 MPH fast. A minor detail not really worth being bothered by ... but it does bother me and I have a Speedohealer (off another bike) that will work (according to Healtech) with the Tracer 9 GT. 1) I know being bothered by a 2 or 3 MPH error is nuts, but I am nuts (apparently) and I have a Speedohealer off another bike that I could install. 2) What concerns me about the install is that this is a direct cut the wires type of install. In particular, the White/Yellow wire which goes to the ABS ECU (accessed by removing - or maybe raising - the gas tank). I guess this is a data wire with speed information on it which is modified by the Speedohealer. The wire is cut, then two wires from the Speedohealer are attached, one to each cut end of the White/Yellow wire (plus hot and ground connections). My bike is so computer controlled that cutting a wire and modifying the data on the wire is concerning due to any unintended consequences, but the Speedohealer folks say it works. Edited June 25, 2023 by etex Link to comment Share on other sites More sharing options...
Ride365 Posted June 25, 2023 Share Posted June 25, 2023 Let us know how it goes and GOOD LUCK, but I'd say most here will say........don't do it. Link to comment Share on other sites More sharing options...
ZigMerid Posted June 26, 2023 Share Posted June 26, 2023 20 hours ago, etex said: My bike reads about 2 - 3 MPH fast Mine reads about 8% fast. I don't think it's a fixed amount that the speedo is off, but rather a ratio. If you're worried about trip time while staying within the speed limit, that 8% is adding about 5 minutes per hour to your trip or about 15-20 minutes per fill-up. Link to comment Share on other sites More sharing options...
