Premium Member 2and3cylinders Posted March 15 Premium Member Share Posted March 15 This is really a rant because at least I believe for the Gen 1 & 2 throttle cables, the 2 basic types of pressure lubing tools don't work. The Motion Pro 3 piece luber and the Cable Life luber won't attach where they are designed to attach at the throttle tube end of the cables because of the silly plastic end fittings. No way they can fit at their lower TB ends. Also the rubber sleeve at the throttle tube housing that pairs both halves together makes it extremely difficult to pull out of the way so lube can get dribbled into each Cable and the cable worked back and forth to work the lube down. The old method of rubber banding a plastic bag at the top and filling it with lube is also hampered by the plastic fittings at the top of each cable. Having the OEM heated grips also adds more frustration and time to maintenance. Has anyone come up with a fast, easy and inexpensive means and method to lube the throttle cables?!!! Link to comment Share on other sites More sharing options...
kilo3 Posted March 15 Share Posted March 15 (edited) 1 hour ago, 2and3cylinders said: Has anyone come up with a fast, easy and inexpensive means and method to lube the throttle cables?!!! Yeah, just don't do it. I'm four years in with an extremely lightened return spring. Hasn't changed a bit. If I had a concern I'd replace the entire cable since it's only 30 bucks. Edited March 15 by kilo3 1 Link to comment Share on other sites More sharing options...
OZVFR Posted March 15 Share Posted March 15 TBH 2&3, I'm in the camp of not believing that these cables need lubrication. My old VFR ended up with 146,000km when I sold it, never lubricated the cables, never noticed any changes. I actually have never lubricated throttle cables on any bike I've ever owned (dirt bikes don't count), and when I was younger I use to do serious miles on all my bikes. They're practically sealed at the top, and not much gets at the end as they are pretty well hidden. There might be a reason why the lube aids don't work maybe. Â Â 1 Link to comment Share on other sites More sharing options...
Ride365 Posted March 15 Share Posted March 15 Motorcycle Cable Lube Kit | Goodbye Sticky Controls – Motobriiz  Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 15 Author Premium Member Share Posted March 15 I guess I'm old school I remember back in the day you needed to lube them and everybody used dry slide but cable life works okay however you still need to lube the throttle tube on The handlebar which I have my own concoction of silicone, Molly Grease and slickoleum The latter was designed specifically for Ride by wire hand grips to simulate the amount of friction you get from a cable operated throttle The clutch cable is not really an issue to lube On my 100,000 Plus VTR I've been lubing the throttle cables the clutch is hydraulic The throttle cables do feel smooth now! I appreciate the input but anyone else have suggestions? I may pick up that hypodermic injector though similar to the dry slide needle Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 15 Supporting Member Share Posted March 15 Bret Since buying my bike brand new my throttle pull always felt heavy or stiff, it was never sticky and always moved open and closed smoothly it was just a heavy effort. My buddy also has a '15 FJ and we swapped bikes many times and the difference in throttle feel was immediately noticeable, infact I was always surprised how two identical 2015 bikes could feel and ride so differently, it always felt like 2 completely different models. Over the years I tried different cable lubes including Dri Slide Cable Lube and nothing made any noticeable improvement, the cable pull was still smooth open and closed but took a lot of effort. Finally a few years ago I bought new cables and it was like a brand new bike, throttle could easily be opened with just thumb and forefinger. I haven't had a single issue with it since. Mine may have had a kink or defect in the cables from the factory?? As @OZVFR mentioned, the throttle housing and cables are essentially a 'closed system' from the top, you would have to put some effort into introducing dirt or contaminants into the cables. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
kilo3 Posted March 15 Share Posted March 15 1 hour ago, 2and3cylinders said: however you still need to lube the throttle tube on The handlebar which I have my own concoction of silicone, Molly Grease and slickoleum That's also a thing of the past, most throttle tubes are ptfe and self lubricating, in fact adding a substance will only collect particles then turn whatever grease you have into a fine abrasive. 3 Link to comment Share on other sites More sharing options...
Steve H Posted March 15 Share Posted March 15 Glad to hear that I'm not a delinquent on cable maintenance after all. Before my FJ I had a VFR for over 20 years and never lubed the throttle cables once. It got a little sticky once, but the issue was at the grip, not the cables. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 15 Author Premium Member Share Posted March 15 I just finished the Spring tension mod, and it's a lot easier know. Go to  I had a brand new cable I could have put in and I didn't. I don't know why I just didn't want to feed new ones through.😆 It is easy enough to do next time, which is now! 1 Link to comment Share on other sites More sharing options...
bwringer Posted March 15 Share Posted March 15 (edited) The cables are lined with plastic slickum, and you shouldn't lube 'em. And as noted above, a new cable set from Mama Yama is pretty dang cheap; $32.31 for my 2015, for example: https://www.onlinecycleparts.com/oemparts/a/yam/546a26cef87002164cb28030/steering-handle-cable Edited March 15 by bwringer 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 15 Author Premium Member Share Posted March 15 Thanks.I have a set in my attic stock I'm breaking down and install them now At part shark they're under thirty bucks shipped if you're a vet 2 Link to comment Share on other sites More sharing options...
