sunshine Posted May 21, 2017 Share Posted May 21, 2017 Hi Guys, As per the service manual, I'm trying to adjust the rear brake-pedal using these two nuts: The problem is, the nut labeled "2" in the diagram is attached to a rubber diaphragm that twists as you move the nut, which in turn unwinds the nut after you adjust it. So, how the hell do you do this? Thanks! Link to comment Share on other sites More sharing options...
Cruizin Posted May 21, 2017 Share Posted May 21, 2017 TO post pics please click the button that says "add image to post" and upload your pic from your computer. It even dumps the pic code into your post for you. Yamaha FZ-10 Forum Yamaha FZ-07 Forum Yamaha Ténéré 700 Forum Link to comment Share on other sites More sharing options...
sunshine Posted May 21, 2017 Author Share Posted May 21, 2017 yeah that doesn't seem to work. all it does is open up a separate window with the image in it. Link to comment Share on other sites More sharing options...
koth442 Posted May 21, 2017 Share Posted May 21, 2017 Can you old one of the nuts with a wrench while turning the other one? '15 FJ09 Link to comment Share on other sites More sharing options...
stuna Posted May 22, 2017 Share Posted May 22, 2017 a dab of oil on the boot then the shaft spins great Link to comment Share on other sites More sharing options...
sunshine Posted May 22, 2017 Author Share Posted May 22, 2017 I'm just gonna re-upload the image again here since the sponsored add image feature doesn't seem to be working: So as you can see from the diagram, the nut marked "2" is attached to a rubber diaphragm that twists if you turn the nut, which then in turn will unwind as soon as you let go of the nut that its attached to. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted May 23, 2017 Premium Member Share Posted May 23, 2017 a dab of oil on the boot then the shaft spins great Great Tip! I struggled last time I adjusted mine, and have been putting off adjusting it again, even though it needed it. Just went out and tried the oil, and it worked great! Thanks Link to comment Share on other sites More sharing options...
carey Posted May 23, 2017 Share Posted May 23, 2017 a dab of oil on the boot then the shaft spins great This is what worked for me. Also, after adjustment, make sure your brake light switched is not on all the time. DAMHIK. Link to comment Share on other sites More sharing options...
