Posted August 6, 20177 yr I discovered, after instantly blowing the 2A fuse in the “Auxiliary DC jack”, which we affectionately call the “cigarette lighter” jack, that 1) all the detailed information about the three fuse boxes and their fuses lies in the Owner’s Manual, (pages 7-33, 7-34 in my book) and not the Yamaha service manual, and 2) you’d better forget intuition, because when you assume the 2A fuse is in the location you’d believe, i.e. Fuse Box #2 and perhaps would be in location 6 or 8, since they are called “Auxiliary fuse” (1 and 2) – you would be wrong. The correct fuse is in Fuse box #3, and it was “Terminal fuse 1” location, (4). The label, inside the cap, showing the fuse ratings, was upside-down on my bike, leading to further confusion. The drawing in the Owner's manual is correct. There was a spare fuse in box #3. By the way, the accessory I was trying to use was a small air compressor, not designed for a motorcycle, and apparently draws far more than 2 amperes.
August 6, 20177 yr Thanks for the info. I have fused wires with SAE connectors from the battery to run my lights, with a join under the seat to power my compressor. Rewired a $12 compressor from the local autobarn with mated SAE connectors (need to get polarity correct). It works well. A few of the Dual Sport guys around here use and swear by Anderson plugs for the same uses. It's sort of a standard with them, so they can all share a compressor/coffee grinder/whatever.
August 6, 20177 yr Similar here suncoaster. I have a SAE connector under the seat, connected to the battery which I can use to charge the battery or connect a compressor to. Red 2015 Tracer, UK spec (well, it was until I started messing with it...)
August 6, 20177 yr PM sent... Riding a fully-farkled 2019 MT-09 Tracer 900 GT from my bayside home in South East Queensland, Australia.
August 6, 20177 yr Thanks for the info. Can't imagine how frustrating that was to discover... Actually I can lol. '15 FJ09
August 6, 20177 yr These days nothing is intuitive any more. What sense does it make to have a 2 amp auxiliary power connector? 10 Amps would require just a $1 more wiring and fuse.
October 26, 20177 yr I blew a fuse the other day using my compressor ??♂️So where is Fuse box #3, and it the “Terminal fuse 1” location?
May 10, 20196 yr That’s so funny I played that game the other day. I ended up getting the multimeter and still getting stumped before I just ended checking all 2amp fuses.
