Faris Posted May 22, 2019 Share Posted May 22, 2019 When switching on ignition, the main headlights is not switched on however upon engine running it automatically switch on the headlights. Does anyone here knows whether if theres a way to disable to the headlights and just have Auxiliary Lights while engine is running or on the move? Wonder if it's possible to do a switch just for Auxiliary Lights. I tried looking into the manual and it seems that the headlight shares the same fuse/assembly. 1 Link to comment Share on other sites More sharing options...
Romanion Posted May 22, 2019 Share Posted May 22, 2019 Any particular reason why you would not like the headlights to be on? You'd get fined by LTA if you don't have your headlights running and cars won't be able to spot you either. 1 Link to comment Share on other sites More sharing options...
skipperT Posted May 22, 2019 Share Posted May 22, 2019 Unplug them. -Skip Link to comment Share on other sites More sharing options...
Faris Posted May 23, 2019 Author Share Posted May 23, 2019 (edited) 16 hours ago, Romanion said: Any particular reason why you would not like the headlights to be on? You'd get fined by LTA if you don't have your headlights running and cars won't be able to spot you either. Just prefer to have a switch where I can on/off. I think it's cooler to have the Daytime Running Light by itself like the Tiger 800 where you have the on/off switch for the headlights I believe you're from Singapore since you know about LTA Edited May 23, 2019 by Faris Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 23, 2019 Supporting Member Share Posted May 23, 2019 On 5/21/2019 at 6:53 PM, Faris said: Does anyone here knows whether if theres a way to disable to the headlights and just have Auxiliary Lights while engine is running or on the move? What part of the world would this be legal? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Romanion Posted May 23, 2019 Share Posted May 23, 2019 I'd rather be visible to drivers with the headlights on all the time tbh. Yeah I'm from Singapore. Sadly I haven't gotten my tracer gt yet. Waiting for my class 2 license in Nov and slowly saving up. 52 minutes ago, Faris said: Just prefer to have a switch where I can on/off. I think it's cooler to have the Daytime Running Light by itself like the Tiger 800 where you have the on/off switch for the headlights I believe you're from Singapore since you know about LTA Link to comment Share on other sites More sharing options...
nigel5 Posted May 23, 2019 Share Posted May 23, 2019 Tiger 800 demo I had a go on had DRL`s on all the time and you had to turn headlights on which made sense to me, why do you need 2 DRL`s on with one headlight on? kind of defeats the object of DRL above headlight😐 Link to comment Share on other sites More sharing options...
Faris Posted May 24, 2019 Author Share Posted May 24, 2019 Exactly my point. Which is why I prefer a switch. Link to comment Share on other sites More sharing options...
norcal616 Posted May 24, 2019 Share Posted May 24, 2019 One headlight stays off/dim to help others judge the distance you are at... Other option is to run the highbeams 24/7 but you would have to adjust the light beam downwards... 1 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
Faris Posted May 24, 2019 Author Share Posted May 24, 2019 1 minute ago, norcal616 said: One headlight stays off/dim to help others judge the distance you are at... Other option is to run the highbeams 24/7 but you would have to adjust the light beam downwards... Is both the high beam adjustable sepaately or when you just 1 then both will be adjusted. Kinda good idea too. Link to comment Share on other sites More sharing options...
FrankQC Posted May 24, 2019 Share Posted May 24, 2019 (Y/B) wire from the ECU to the headlight LED's DC-DC converter. That (Y/B) wire goes to ground as soon as the engine is running, turning ON the headlight and allowing Hi-Beam through the handlebar switch. On the LED controller connector (below the cluster), (Y/B) is the negative (-) trigger for the LOW-Beam, (Y) is the negative (-) trigger for the High-Beam from the handlebar switch. (I would personally NOT do that for the same reasons as Romanion) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 24, 2019 Supporting Member Share Posted May 24, 2019 31 minutes ago, norcal616 said: One headlight stays off/dim to help others judge the distance you are at... Other option is to run the highbeams 24/7 but you would have to adjust the light beam downwards... Thats exactly what I have done on my bike. I have the high switch on all the time so both front lamps are lit, I just aimed the 2nd lamp downward. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
norcal616 Posted May 24, 2019 Share Posted May 24, 2019 46 minutes ago, Faris said: Is both the high beam adjustable sepaately or when you just 1 then both will be adjusted. Kinda good idea too. I have no clue- I find the low beam pretty good for night time riding but my exception is I have been a 3rd shifter for the last 16yrs of my life... 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
