Supporting Member maximNikenGT Posted June 1, 2021 Supporting Member Share Posted June 1, 2021 Is it true that the Niken fuel gauge needle seems to not reflect an accurate reduction in fuel level? According to specs, Niken GT fuel capacity is supposedly 4.8 gallons / 18.17 L. Assuming 35 MPG with a full tank then: a. At a 25% of the tank being used should be reflected after 42 miles, b at 50% tank consumed should be reflected at about 84 miles and c. At 75% tank consumed should be reflected at about 126 miles. d. At empty should be at about 168 miles (4.8 gallons x 35mpg). If assuming 45 MPG, then: a 25% of the tank being used should be reflected after 54 miles, b at 50% tank consumed should be reflected at about 108 miles c. At 75% tank consumed should be reflected at about 162 miles. d. At empty, theoretical range should be at about 216 miles (4.8 gallons x 45 mpg). What is everyone generally seeing at 25\50\75\100% of tank consumption? Hopefully no one has had to test the 100% fuel scenario... Also are the Tracer fuel gauges inaccurate as well? 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
GTO MIKE Posted June 1, 2021 Share Posted June 1, 2021 (edited) I assume if set up like the Tracer the Gauge will not come off full till reaching the 1/2 tank stay their till 1/4 tank then show remaining when reaching low levels. Sounds odd but OK once you get used to it. Mike Edited June 1, 2021 by GTO MIKE missing letter 2 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted June 2, 2021 Supporting Member Share Posted June 2, 2021 On my 2017 the same. Full indicated until half a tank, no change till a 1/4 of a tank. When it started flashing at me I got 20 miles at about 50mpg. Promptly added 4.4 gallons and wiped the sweat from my brow. 1 Link to comment Share on other sites More sharing options...
duhs10 Posted June 2, 2021 Share Posted June 2, 2021 Its not a matter of the gauge being inaccurate, it is due to the shape of the tank... the attached image is referring to a FZ-09 but the concept is the same. 1 1 '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 2, 2021 Supporting Member Share Posted June 2, 2021 After the first few tanks of fuel, you learn to ignore the fuel gauge and rely on the trip meter instead. Depending on your right wrist, you start paying closer attention to upcoming fuel stations somewhere between 160 and 180 miles. 6 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted June 2, 2021 Supporting Member Share Posted June 2, 2021 1 hour ago, betoney said: After the first few tanks of fuel, you learn to ignore the fuel gauge and rely on the trip meter instead. Depending on your right wrist, you start paying closer attention to upcoming fuel stations somewhere between 160 and 180 miles. For the OP - And if you use your trip meter for multiple trips and are unsure of your total mileage at any point then just reserve and utilise the 'spare' trip meter to monitor full to empty tanks. i.e., reset trip meter number two every time you fill up. 1 1 Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted June 3, 2021 Author Supporting Member Share Posted June 3, 2021 On 6/1/2021 at 10:21 PM, duhs10 said: Its not a matter of the gauge being inaccurate, it is due to the shape of the tank... the attached image is referring to a FZ-09 but the concept is the same. That explains a lot actually. Thanks for posting. This explains why the Nikens have a digital fuel display that displays fuel in proportional segments like the Tracer. So technically the Fuel level level display is accurate, it's just the RATE of fuel needle drop over time isn't linear and that is what throws everybody off. 1 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 3, 2021 Supporting Member Share Posted June 3, 2021 8 minutes ago, maximNikenGT said: This suggests that the Nikens should probably have a digital fuel display that displays fuel in proportional segments like the Tracer. Yes, the Niken, FJ09 and Tracer GT all read the same, 5 segments with the first larger segment indicating about half a tank.. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted June 3, 2021 Author Supporting Member Share Posted June 3, 2021 1 hour ago, betoney said: Yes, the Niken, FJ09 and Tracer GT all read the same, 5 segments with the first larger segment indicating about half a tank.. Thanks for the clarification - all this time I never noticed the first fuel bar being bigger than the rest. I just thought that was done for better legibility purposes in the instrumentation... 1 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted June 3, 2021 Author Supporting Member Share Posted June 3, 2021 From the service manual, 4.0L / 1.08 US gallons in the fuel reserve ( when the fuel light comes on). 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
