Rdecae81 Posted March 3, 2022 Share Posted March 3, 2022 I am doing a reset of the Steering stem Lower Ring nut Page 3-20 of the Yamaha service manual Lower Ring Nut initial torque = 52nm Lower Ring Nut Final Torque = 18nm One what am I missing Two anyone know the correct Torque for the lower ring nut? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted March 3, 2022 Supporting Member Share Posted March 3, 2022 8 minutes ago, Rdecae81 said: I am doing a reset of the Steering stem Lower Ring nut Page 3-20 of the Yamaha service manual Lower Ring Nut initial torque = 52nm Lower Ring Nut Final Torque = 18nm One what am I missing Two anyone know the correct Torque for the lower ring nut? I just looked at the service manual on my older 2015 model and it says the same thing, very confusing. Yamaha manuals and specifically some torque figures are known to be questionable. @skipperT - do you have any insight on this? ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted March 3, 2022 Premium Member Share Posted March 3, 2022 If I'm not mistaken, and I certainly could be, the initial setting is used after replacement of new bearings, cages and races to "bed" them to each other. Then after this first tensioning you're then to back-off the preload and retension using the second lower setting. I usually pretension based on feel because it is often difficult to use a torque wrench for this procedure. The goal is to have them bedded snugly but not overtightened so that the cages are crushed and races dinged. Honda, for example, specify how to check the force needed to turn the forks using a tension scale like a fish weight scale (I have a digital scale that is metric & inch that goes up to 85#s). 1 Link to comment Share on other sites More sharing options...
skipperT Posted March 3, 2022 Share Posted March 3, 2022 4 hours ago, betoney said: I just looked at the service manual on my older 2015 model and it says the same thing, very confusing. Yamaha manuals and specifically some torque figures are known to be questionable. @skipperT - do you have any insight on this? Sure, follow the book. 🤣 I’ve used those figure many times over the years. @2and3cylinders pretty much covered it above, but what the Factory means is to initially torque it to 52 Nm, loosen the nut, and re-torque to 18Nm. I would add that I typically rotate the lower triple tree back and forth several times to help seat everything and give an accurate torque figure. I then torque the nut again, wiggle the stem, and tighten it a third time. Install the rubber washer, install the upper nut BY hand, line up the notches and insert the locking plate (if any). I also like a higher torque figure (probably around 22-25 Nm as a final torque if using stock bearings as long as they don’t bind. Helps with the steering head shake of these and the MT09 models. if using tapered bearings (Allballs, etc) the factory specs should be used as a guideline only, usually those require a higher torque figure to keep them rotating, not binding, and not clunking. It’s really a “by feel” method more then anything if using aftermarket bearings (which are WAY better than stock!) If you look up how to set Fall-away on Harley Davidson soft tails, sportys, or Dyna models you can use a similar process after you’re done to see if it’s in the ballpark of good tightness without having to test ride and re-adjust. I don’t have time, but I’m sure there’s YouTube vids out there… -Skip 2 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted March 3, 2022 Supporting Member Share Posted March 3, 2022 1 hour ago, skipperT said: Factory means is to initially torque it to 52 Nm, loosen the nut, and re-torque to 18Nm. I will just add... loosen, but not enough for the bearing/races to separate. 2 1 Link to comment Share on other sites More sharing options...
Rdecae81 Posted March 4, 2022 Author Share Posted March 4, 2022 yes watched a video and you are correct, I understand now. thanks. Link to comment Share on other sites More sharing options...
