Gophman Posted April 4, 2023 Share Posted April 4, 2023 Hi, my 2017 tracer is having issues since I brought it out of isolation, it starts fine when cold and hot but if I leave the bike for a while (till it's below running temp but not fully cold) I hit the button and the bike turns over and catches and immediately shuts off. The only way to start it is with holding the throttle open while turning over and holding the revs above idle for a few seconds until it will idle... runs spot on otherwise. Link to comment Share on other sites More sharing options...
Gordie Posted April 4, 2023 Share Posted April 4, 2023 Wondering if it's a fuel issue? Depending on how long it was in storage maybe the gas has gone bad. Link to comment Share on other sites More sharing options...
Gophman Posted April 4, 2023 Author Share Posted April 4, 2023 I initially put it down to stale fuel but it's went through a full tank of fresh stuff. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted April 4, 2023 Premium Member Share Posted April 4, 2023 Sounds like possibly dirty throttle bodies or theyre gunked up possibly the starting circuit or partially clogged fuel injectors. Maybe even the fuel filter has an isue start doing diagnostics. Link to comment Share on other sites More sharing options...
Gordie Posted April 5, 2023 Share Posted April 5, 2023 7 hours ago, Gophman said: I initially put it down to stale fuel but it's went through a full tank of fresh stuff. Like 2and3cylinnders said maybe its the fuel filter. I'd suggest changing the spark plugs as a quick way to eliminate an issue with them. Good luck with it. 1 Link to comment Share on other sites More sharing options...
whisperquiet Posted April 6, 2023 Share Posted April 6, 2023 (edited) On 4/4/2023 at 7:55 AM, Gophman said: Hi, my 2017 tracer is having issues since I brought it out of isolation, it starts fine when cold and hot but if I leave the bike for a while (till it's below running temp but not fully cold) I hit the button and the bike turns over and catches and immediately shuts off. The only way to start it is with holding the throttle open while turning over and holding the revs above idle for a few seconds until it will idle... runs spot on otherwise. When did it last have a valve clearance check? Tight valves lead to start problems when hot. But, run a few tanks of fuel through it to clean things up. Edited April 6, 2023 by whisperquiet Link to comment Share on other sites More sharing options...
OZVFR Posted April 6, 2023 Share Posted April 6, 2023 You probably need to give a bit more information to get a somewhat accurate answer. How many kilometres on the bike, history, where do you live? Too many variables to decide from your very narrow description. The more info you give, the more relevant answer you will get. Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted April 6, 2023 Premium Member Share Posted April 6, 2023 On 4/4/2023 at 6:55 AM, Gophman said: Hi, my 2017 tracer is having issues since I brought it out of isolation, it starts fine when cold and hot but if I leave the bike for a while (till it's below running temp but not fully cold) I hit the button and the bike turns over and catches and immediately shuts off. The only way to start it is with holding the throttle open while turning over and holding the revs above idle for a few seconds until it will idle... runs spot on otherwise. My 2016 has done this since new. 60,000 miles, two major services by dealer and still does it. Usually smell gas when it does it. I'll ride somewhere, eat lunch and that's long enough for it to act up. First start or quick restart no issues. Forgot to tell dealer about it when getting serviced. Next time. Link to comment Share on other sites More sharing options...
Brentinpdx Posted April 7, 2023 Share Posted April 7, 2023 Sounds like a vapor lock issue. What about a bad engine ground, a bad battery ground, or a clogged air cleaner? How about the crank position sensor or connection? Link to comment Share on other sites More sharing options...
Jfundo Posted April 7, 2023 Share Posted April 7, 2023 I have a similar issue on my '19 with 7k miles. Mine doesn't sound as bad, but I can pull it out of the garage on a cold day after sitting for a month and it fires up with 1/2 second push of the starter. Ride for 30 miles, make a quick stop, try to restart and it cranks over for 4 seconds, starts, dies, and then on second try works perfectly again. My plan is to go through it this spring, will be the first time even having the tank off. Link to comment Share on other sites More sharing options...
