rtaylor522 Posted June 14, 2018 Share Posted June 14, 2018 So, my used fj09 came with the national v stream screen installed, but I'd like to give the stock windscreen a try. Problem is I have a box full of brackets and screws, and it's not as obvious as I was hoping for. Does anyone have good pics of the stock screen installed or better yet the parts diagram? I feel like I'm missing some hardware anyways. Thanks! Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted June 14, 2018 Supporting Member Share Posted June 14, 2018 Hi @rtaylor522 - See if this helps with what you’re looking for: https://www.partzilla.com/catalog/yamaha/motorcycle/2015/fj09-fj09fr/windshield As long at the backing plate for the windscreen is there (part 4 in this parts diagram), then the only thing you should need are the four sets of screws and spacers (parts 2 & 3) that hold the windscreen in place. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 14, 2018 Supporting Member Share Posted June 14, 2018 I'd like to give the stock windscreen a try. Don't put a lot of time and effort into fitting the stock screen, after a few minutes of wind noise and helmet buffeting you will probably be looking at a replacement like so many other FJ owners. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
rtaylor522 Posted June 14, 2018 Author Share Posted June 14, 2018 Can't be worse than the vstream.....me and that thing do not get along....I've resorted to no screen. The diagram helps....are these screws that attach will dscreen to backer plastic? I have some plastic screws. Link to comment Share on other sites More sharing options...
sdwillie Posted June 14, 2018 Share Posted June 14, 2018 Can't be worse than the vstream.....me and that thing do not get along....I've resorted to no screen. The diagram helps....are these screws that attach will dscreen to backer plastic? I have some plastic screws.Stock shield is horrendous indeed. I have the Vstream with this setup and it works really well: MRA X-Creen 2016 FJ09 Link to comment Share on other sites More sharing options...
nicksta43 Posted June 14, 2018 Share Posted June 14, 2018 Can't be worse than the vstream..... I think you'll be surprised. And yes use the four plastic screws. Link to comment Share on other sites More sharing options...
koth442 Posted June 14, 2018 Share Posted June 14, 2018 When you decide the stock screen is also utterly terrible, CalSci is my favorite aftermarket screen haha! '15 FJ09 Link to comment Share on other sites More sharing options...
duhs10 Posted June 14, 2018 Share Posted June 14, 2018 Puig touring with clip on deflector has been my solution.. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted June 14, 2018 Premium Member Share Posted June 14, 2018 Madstad for me......... Link to comment Share on other sites More sharing options...
rtaylor522 Posted June 14, 2018 Author Share Posted June 14, 2018 Well I'll have to forgo the torture chamber of the stocker....the plastic screws are apparently all messed up, so sounds like I shouldn't buy new ones. Used some washers to shim vstream and slope it back more....it changed it, but I. Not sure it's better. I'm tempted to try one of those clip on visors but feel it may be right in my line of sight....we will see what I do next. Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted June 14, 2018 Supporting Member Share Posted June 14, 2018 @rtaylor522 - As you can see, there are LOTS of opinions of the best windscreen option... the one thing that's almost universally accepted is that the stock screen leaves plenty of room for improvement. I actually find that no screen at all is noticeably better than the stock screen, both in terms of wind noise and turbulence. It's actually almost funny that they were somehow able to engineer, test, and approve a windscreen that unfavorably compares to nothing at all. Link to comment Share on other sites More sharing options...
