CJ3cyl Posted April 19, 2021 Share Posted April 19, 2021 Options are good! I'm amazed at the clever remedies and the workmanship that has gone into them. Link to comment Share on other sites More sharing options...
CJ3cyl Posted April 22, 2021 Share Posted April 22, 2021 (edited) On 4/19/2021 at 11:05 AM, Denideul said: Also available There with two balls. The kit I ordered indeed came with two balls. Sorry! Something went wrong! Edited April 22, 2021 by CJ3cyl Link to comment Share on other sites More sharing options...
CJ3cyl Posted April 23, 2021 Share Posted April 23, 2021 Link to comment Share on other sites More sharing options...
dejan Posted August 19, 2021 Share Posted August 19, 2021 On 3/14/2019 at 2:22 AM, motopumps said: Got a bit more done and have mounted the frame on the bike with a VStream Sport Touring Shield. Please excuse the crappy pix and rough finish on the mount. Still prototyping. Very stiff and looks good with proper clearance from shield and enough room for your hand below the bar to adjust the height of the shield. Still working on the design for the GPS mount that attaches to the cross bar. It has a standard AMPs bolt pattern so my Zumo 550 cradle will attach. Going to make it out of Delrin and probably also a version out of 6061 to compare. Delrin is about half the weight, and strength is not an issue in this application. Have made the cross bar mount wider as of this evening. Rob hello! looks awesome do you sell&ship them too ? thanks in advance Link to comment Share on other sites More sharing options...
spanky127 Posted February 9, 2022 Share Posted February 9, 2022 Are you selling this? If not can you send me some specs to build on of my own? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted February 9, 2022 Premium Member Share Posted February 9, 2022 BTW I replaced the OEM nylon screws with black oxide finished steel button head cap screws and added rubber and nylon washers under their heads. I have a box of the screws left overif anyone wants some. Link to comment Share on other sites More sharing options...
