jdavis Posted July 29, 2019 Share Posted July 29, 2019 (edited) Anyone have LED lights attached to the front wheel guard, if so, how well do they handle the road shock? Edited July 29, 2019 by jdavis Link to comment Share on other sites More sharing options...
TorqWrench Posted August 23, 2019 Share Posted August 23, 2019 I haven't added LEDs to my Tracer yet but I had some 2" 10w Cree lights mounted on the bracket that held the front fender to the forks on my 2012 V-Strom. I never had any issues at all and they really lit up the road. They were too bright to use anywhere in traffic when pointed straight ahead. I offset them about 5* to each side and just a couple of degrees down. This did not bother oncoming traffic and I still had a HUGE improvement in visibility, especially ditches and treelines where critters like to appear from at night. Hope this helps. Dan Link to comment Share on other sites More sharing options...
jdavis Posted August 24, 2019 Author Share Posted August 24, 2019 All sorted now thanks @TorqWrench. I also pointed them down a bit. 1 Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 25, 2019 Premium Member Share Posted August 25, 2019 I mounted mine between the forks, easier to find solid mounting points up above, and it didn't seem to provide much more visibility down lower. Also less likely to get damaged in a drop. IMHO - the ideal location would be on the engine guards - wider placement and easier to run wires there.... Link to comment Share on other sites More sharing options...
Supporting Member whistler Posted August 25, 2019 Supporting Member Share Posted August 25, 2019 On 8/24/2019 at 8:19 AM, jdavis said: All sorted now thanks @TorqWrench. I also pointed them down a bit. +1. I've had fork-mounted LEDs on my last several bikes for tens of thousands of miles. Aimed them all 3 degrees down from horizontal; have never had an issue with useful coverage nor blinding oncoming traffic. They work. 1 2019 Yamaha Tracer 900 GT (Annabelle) 2013 Suzuki V-Strom DL650 (Juliette) 2013 Yamaha FJR 1300 (Rachel) 2008 Suzuki Bandit 1250S (Fiona) 2006 Honda VFR800 (Jenny) 2005 Suzuki V-Strom DL650 (Hannah) 2003 Honda Shadow Sabre VT1100 (Veronica) Link to comment Share on other sites More sharing options...
TorqWrench Posted August 26, 2019 Share Posted August 26, 2019 I had fork mounted leds on my '12 V-Strom and then on the engine guards on my '14 Strom. I haven't added them to my Tracer yet, but I'm considering it. AdventureTech is in the works on a led mount kit similar to the one they make for the FJ. I'll see how that turns out and then decide where I want to mount my leds. 1 Link to comment Share on other sites More sharing options...
jdavis Posted August 26, 2019 Author Share Posted August 26, 2019 17 hours ago, DavidS said: I mounted mine between the forks, easier to find solid mounting points up above, and it didn't seem to provide much more visibility down lower. Also less likely to get damaged in a drop. IMHO - the ideal location would be on the engine guards - wider placement and easier to run wires there.... I had a DRL mounted between the forks, but the beak now blocks it, so its gone. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 27, 2019 Premium Member Share Posted August 27, 2019 The GV case guards makes it easy to mount driving lights at the optimum height Down on the forks in my opinion they are too low but up higher you can also not only tilt them down but left right easier On 8/26/2019 at 5:31 AM, jdavis said: I had a DRL mounted between the forks, but the beak now blocks it, so its gone. Link to comment Share on other sites More sharing options...
jdavis Posted August 28, 2019 Author Share Posted August 28, 2019 On 8/26/2019 at 4:24 AM, whistler said: +1. I've had fork-mounted LEDs on my last several bikes for tens of thousands of miles. Aimed them all 3 degrees down from horizontal; have never had an issue with useful coverage nor blinding oncoming traffic. They work. 13 hours ago, 2and3cylinders said: The GV case guards makes it easy to mount driving lights at the optimum height Down on the forks in my opinion they are too low but up higher you can also not only tilt them down but left right easier @2and3cylinders,My DRL's are mounted low on the fork legs and my Driving Lights are on the screen. Link to comment Share on other sites More sharing options...
mellow Posted August 28, 2019 Share Posted August 28, 2019 On 8/26/2019 at 5:31 AM, jdavis said: I had a DRL mounted between the forks, but the beak now blocks it, so its gone. Anyone know if the FJ and Tracer forks are the same size? Would like to add those upper fork mounts for an aux light bar. ST-Owners Link to comment Share on other sites More sharing options...
WindsorPhil Posted August 28, 2019 Share Posted August 28, 2019 My Cree lights are mounted to the original reflector brackets near the brake caliper. They work perfect and light-up the roadway perfectly at night. My riding group says they look great from a distance also. No issues with coming loose from vibration or going out of alignment yet. I wired them to the original leads under the headlight where the OEM lights would be plugged into. They stay on all the time with the key switch. 1 Link to comment Share on other sites More sharing options...
jdavis Posted August 29, 2019 Author Share Posted August 29, 2019 21 hours ago, mellow said: Anyone know if the FJ and Tracer forks are the same size? Would like to add those upper fork mounts for an aux light bar. The mounts I used were 2" (49mm) light mounts. I would think that the Tracer and FJ are the same. 1 Link to comment Share on other sites More sharing options...
