v1nn1e Posted November 1, 2019 Share Posted November 1, 2019 I'm sure I read through the manual but confess I completely missed that the three bars selectable from the handlebar controls can have their actual amount of heat set from the settings menu. My two-bar/middle position was too hot at anything above 5 degrees C so I've lowered it to 3 from 4. The three-bar/top position was set to 7! I guess that's when you ride in -5 degrees C! I've reduced that to 5 which I reckon should be plenty if I'm out when it's freezing. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 1, 2019 Supporting Member Share Posted November 1, 2019 28 minutes ago, v1nn1e said: I'm sure I read through the manual but confess I completely missed that the three bars selectable from the handlebar controls can have their actual amount of heat set from the settings menu. My two-bar/middle position was too hot at anything above 5 degrees C so I've lowered it to 3 from 4. The three-bar/top position was set to 7! I guess that's when you ride in -5 degrees C! I've reduced that to 5 which I reckon should be plenty if I'm out when it's freezing. I have my 3 heat levels set to 3/5/7. I have used level 2 a few times, but never needed level 3. These grips get HOT!! ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
WindsorPhil Posted November 1, 2019 Share Posted November 1, 2019 I am at 3-4 & 5 with mine. I also changed to BarkBuster Storm hand guards. Link to comment Share on other sites More sharing options...
kaia Posted November 5, 2019 Share Posted November 5, 2019 I didn't realize until now that you could set the temp... awesome. I used the stock settings, and the grips got so hot at 2 bars that i didn't go to 3 very often. Link to comment Share on other sites More sharing options...
iamthedruman Posted November 5, 2019 Share Posted November 5, 2019 Just installed my Hotgrips using @Duke's method. Worked like a charm. Took'er out for the last pre-winter sleep spin around 5ish Celcius degrees yesterday with the grips set to 3/7/10... 10 heated things up right quick! Will be readjusting next spring to 3/5/7 as others have mentioned! 1 Link to comment Share on other sites More sharing options...
v1nn1e Posted November 8, 2019 Author Share Posted November 8, 2019 There was a ground frost today and the air temp gauge was down to 3 degreesC. Had the grips on 3 bars, which is set to level 5 and my gloves didn't melt! Reckon I will up that to 6 now and increase all the other levels a bit through to next March! Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted November 8, 2019 Supporting Member Share Posted November 8, 2019 On 11/4/2019 at 9:19 PM, iamthedruman said: Just installed my Hotgrips using @Duke's method. Worked like a charm... Excellent. Saw in another thread that you also tried the Heat Demons (I could be wrong)... you no like? Could measure, but gonna ask anyway 😀... which Hot Grips Part# did you buy? Link to comment Share on other sites More sharing options...
iamthedruman Posted November 9, 2019 Share Posted November 9, 2019 Bah! Whoops, I meant the Heat Demons. I used the set indicated in the other thread. My bad. Just a free user so can't edit it any further. 😋 1 Link to comment Share on other sites More sharing options...
foxtrot722 Posted November 16, 2019 Share Posted November 16, 2019 Just finished installing a set of factory heated grips, wanted the clean install and not need to add any switches. The install was straight forward and looks great when complete. Set the heat control at 3-5-7, haven't gone for a ride yet, will give feed back after the test ride. 1 1970 DT-250 / 1972 250MX / 1973 360MX / 1974 250MX & 1974 CZ 400 Red Frame & SC 500 / 1978 YZ 250 / 1979 YZ250 / (2) 1980 YZ 250 / 1986 YZ 490 / 1989 YZ250 WR / 1994 YZ 250 / (2) 2002 YZ 426 / 2007 YZ 450 / 2007 DR 650, 2015 FJ 09 / 2020 YZ 250 Link to comment Share on other sites More sharing options...
