Ddog gt Posted May 3, 2022 Share Posted May 3, 2022 My question iS about feeler gauge length. My set is only 2 1/2 inches long will it be long enough to check the valves on the Tracer 900 engine if not what would be the ideal length? Also can you reuse the valve cover gasket or should that be replaced with a new one? This will be the first time I’ve ventured into a Yamaha triple although I have done many valve adjustments over the years the most involved one was on a K 1600 GT motor now that took some work thank you in advance for any response. Duane Link to comment Share on other sites More sharing options...
skipperT Posted May 3, 2022 Share Posted May 3, 2022 Yes to both questions. You may find 1 length more or less useful depending on what you are willing to take off the bike when accessing the valve cover for removal. I pull the rad because I KNOW the cams are coming out. Others swing it down and out of the way, or simply put up with it and scrape their knuckles. NO adhesive on the “1/2 moon” part of the gasket btw. And ok to reuse. -Skip 2 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted May 3, 2022 Supporting Member Share Posted May 3, 2022 You may find angled leaves more convenient to use on the intake side. I replace the gasket... but YMMV. Link to comment Share on other sites More sharing options...
Ddog gt Posted May 4, 2022 Author Share Posted May 4, 2022 Thank you for the replies. I plan on removing the radiator as I will have the forks off for oil service and am also doing a coolant change. A good time to do some cleaning. Will pick up some angle gages. Will pickup a gasket when I go to buy the coolant. Much appreciate the advice, Duane 1 Link to comment Share on other sites More sharing options...
Buggy Nate Posted May 4, 2022 Share Posted May 4, 2022 11 hours ago, skipperT said: Yes to both questions. You may find 1 length more or less useful depending on what you are willing to take off the bike when accessing the valve cover for removal. I pull the rad because I KNOW the cams are coming out. Others swing it down and out of the way, or simply put up with it and scrape their knuckles. NO adhesive on the “1/2 moon” part of the gasket btw. And ok to reuse. -Skip Come on Skip my valves are still in spec at 50,000ks! 🤣 I know I’m one of the rare ones! Link to comment Share on other sites More sharing options...
skipperT Posted May 4, 2022 Share Posted May 4, 2022 5 hours ago, Buggy Nate said: Come on Skip my valves are still in spec at 50,000ks! 🤣 I know I’m one of the rare ones! Then you must be measuring it wrong, BN! 🤣 yeah you probably just won the cylinder head lottery. That is rare for sure, I’m still in disbelief that there are some out there. (And secretly question if people are forcing feeler gauges in under the cam lobe when measuring but I know you know better…) -Skip 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 5, 2022 Premium Member Share Posted May 5, 2022 I love the feel of my lubed feeler gage in tight spots, you never forget the first time but it's not as easy when you get older. 1 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 5, 2022 Supporting Member Share Posted May 5, 2022 7 hours ago, 2and3cylinders said: ... but it's not as easy when you get older. ...or to be as enthusiastic about it. 2 1 Link to comment Share on other sites More sharing options...
Buggy Nate Posted May 5, 2022 Share Posted May 5, 2022 20 hours ago, skipperT said: Then you must be measuring it wrong, BN! 🤣 yeah you probably just won the cylinder head lottery. That is rare for sure, I’m still in disbelief that there are some out there. (And secretly question if people are forcing feeler gauges in under the cam lobe when measuring but I know you know better…) -Skip Hahaha shit, way to break my heart! 🤣 I do wonder if riding style makes a difference. I don’t valve bounce like I used to and much prefer to use the abundant torque of the engine. It is probably a once every couple of months if that when it gets ridden in anger! 😂 1 1 1 Link to comment Share on other sites More sharing options...
PhotoAl Posted May 6, 2022 Share Posted May 6, 2022 I've found that having both a straight and angled set makes thing easier. 1 Link to comment Share on other sites More sharing options...
skipperT Posted May 8, 2022 Share Posted May 8, 2022 On 5/4/2022 at 5:22 PM, 2and3cylinders said: I love the feel of my lubed feeler gage in tight spots, you never forget the first time but it's not as easy when you get older. That got dirty quickly… 🤣 -S 1 1 Link to comment Share on other sites More sharing options...
