TracerNed Posted September 10, 2022 Share Posted September 10, 2022 I purchased a 2021 Tracer 9GT in Sept 2021 and this has been an issue since I have owned the bike. When using the cruise control the decel button does not always works correctly. With the CC turned on I get up to speed and hit the set button, and the bike stays at that speed. If I am gaining on someone and hit the decel button one of 3 things happen: - - Nothing, no change in speed - - It slows 1 mph (is supposed to be 2 mph per the manual) - - It correctly slows 2 mph When I hit the decel a second time, it works correctly and drops 2 mph. It does this in any gear. This also happens after I hit resume. I am curious if any others have noticed this? I have an appt with the dealer to look at it. Link to comment Share on other sites More sharing options...
whisperquiet Posted September 10, 2022 Share Posted September 10, 2022 (edited) That happened with me on an older Super Tenere with factory cruise. I opened the switch housing slightly and sprayed contact cleaner in the switch while working all of the buttons and switches …… problem solved. Edited September 10, 2022 by whisperquiet Link to comment Share on other sites More sharing options...
KrustyKush Posted September 10, 2022 Share Posted September 10, 2022 Not exactly, but a few times I’ve hit the decel button and perhaps it only dropped 1 rather than 2. I will pay closer attention and nail it down. I prefer a 1 interval, so when it happened I noticed it but couldn’t swear that it actually happened. Usually, it drops 2. However I have not had it fail to respond. 1 Link to comment Share on other sites More sharing options...
TomTracer Posted September 11, 2022 Share Posted September 11, 2022 I hit the decel when it appears I'm gaining on a vehicle ahead where it may put me too close. I use my eyes to judge when I've slowed enough. The speed change is not instantaneous, and I dont care what the UM states. 1 Link to comment Share on other sites More sharing options...
kiseliok Posted September 11, 2022 Share Posted September 11, 2022 Here is what I think is happening (I looked through the owners' and shop manual, and cannot confirm this). After setting the cc, there is some sort of 'timeout' - whether mechanical (first change) or time-based. If you try to '-' after setting the speed, no action is taken. It works on the second click though. If you set your speed to an odd number - ex. 61mph - the first change will be to either 60 or 62, depending which way you go. After that, '+' and '-' go at 2mph (per manual and observed). I love having cc on the bike and I used it quite often, so this is based purely on my observations. 2 Link to comment Share on other sites More sharing options...
