fredogauvino Posted July 5, 2015 Share Posted July 5, 2015 After looking around to buy a tailbag for the FJ, I really could not find exactly what I wanted... Every one was either too large or too small, too long or too narrow... I first converted a tankbag, but it was constantly touching my butt on every bump, which was very annoying. So, in a momentarely lapse of reason, I decided to build one myself. One that would have the following characteristics : [ul type=disc] [*]As wide and large as the tail section allows[*]Waterproof[*]Not touching my butt.[*]Not scratching paint.[*]Can hold a rainsuit and more.[*]Easy to remove/install.[/ul] I went to the local Club Tissu store, and bought some tough waterproof polyester, along with a waterproof zipper, reflective stripes and some rubbery slip proof cloathing. Total expenses 60$... Then, using cardboard, I created the shape of the tailbag that I would really like. The bottom section follows the size of rear seat + handgrab. I then used the cardboard pieces as templates, and cutted all the polyester pieces required. I have a semi-professionnal sewing machine that is strong enough to sew thick stuff. Bottom The floor is composed of 2 layers of polyester with 1/4 thick form foam, another layer of rubbery anti-slip material will ensure no slippage once installed on bike. Walls To add rigidity, each walls are 2 layers thick with a piece of crazy carpet plastic sandwitched between the two layers... Cover The top is composed of 3 pieces, it was lacking rigidity, layers were separating, so I had to improvise and sew a line with a G (Gauvin) in the middle. Bye Bye waterproofiness..., but at least it holds its shape, and this adds a little design to it. Straps I used small plastic 1/2" straps holders with D shape rings to secure the bag, this works quite well. Sewing All this took about 3-4 hours. Then the toughest part was to sew the zipper. That was really tough. Just the zipper took me 3 hours too, with many reattempts and modifications. I made many mistakes, but overall the final prototype is good enough to be usable. In the end I was still not satisfied with the results, but hey, it works. That part does not look professionnal at all... If I add the cost of material with work 8x15$ an hour, I will need to sell those at least 180-200$ to start making money... You cannot beat the Chineses ! So don't ask me to make one for you. (puke) The end result is THE perfect tailbag, Ok, maybe not good enough to be sold, but It does not move at all, you really can't tell its there at all. It is surprisedly roomy, and fit with the edgy design of the bike. When empty, it holds its shape well. Here is what it looks like once installed. Any comments will be appreciated ( good or bad ) Link to comment Share on other sites More sharing options...
mjsracing Posted July 5, 2015 Share Posted July 5, 2015 That looks like the perfect 1-up tail bag. Nice work! I suspect you could sell them easily. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
thespaceman Posted July 5, 2015 Share Posted July 5, 2015 Nice work Fred! I'm always impressed by guys like you who can create something of value from scratch. I modded my Sedici (Cycle Gear) tank bag; it works but its far from the perfect fit and size of your bag. Link to comment Share on other sites More sharing options...
Premium Member Trambo Posted July 5, 2015 Premium Member Share Posted July 5, 2015 Nice work! I wish I was that handy to make things! 2015 Stealth Grey FJ-09 Pilot Base of Operations: Chesterfield, VA Farkels? Lots, nothing flashy, but all functional... Link to comment Share on other sites More sharing options...
redfjniner Posted July 6, 2015 Share Posted July 6, 2015 Nice job. I added this to the How To Index. DIY Tailbag: Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 106,000 m (Lost compression in #2 Cyl.) Link to comment Share on other sites More sharing options...
troll Posted July 6, 2015 Share Posted July 6, 2015 very cool, I to am impressed by the girls and boys that are innovative and creative. nice job! Coming to you from the frozen wastelands of the barren north Link to comment Share on other sites More sharing options...
Premium Member keithu Posted July 7, 2015 Premium Member Share Posted July 7, 2015 The shape looks great! I know you said that the G stitching leaks. What about the other seams? Link to comment Share on other sites More sharing options...
fredogauvino Posted July 7, 2015 Author Share Posted July 7, 2015 The other seams are sealed with 3m silicone seam tape. It is a tape that you put between layers or iron on. This cannot work with the G that I stitched. I might try with silicone spray inside... Last day I washed my bike and soaked the bag badly. Some drops came thru the G spot but none elsewhere... Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted July 7, 2015 Premium Member Share Posted July 7, 2015 The other seams are sealed with 3m silicone seam tape. It is a tape that you put between layers or iron on. This cannot work with the G that I stitched. I might try with silicone spray inside... Last day I washed my bike and soaked the bag badly. Some drops came thru the G spot but none elsewhere... So what you are saying is that there is a problem with your G spot soaking through? Interesting. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
redfjniner Posted July 7, 2015 Share Posted July 7, 2015 Last day I washed my bike and soaked the bag badly. Some drops came thru the G spot but none elsewhere... Don't do that. Caulk it up as a test. Please tell us again why it's the G spot? Ken, Candy Ass L.D.R. Sleeps 8 hours (2)2005 FJR1300abs: 230,000 m 2015 FJ-09: 106,000 m (Lost compression in #2 Cyl.) Link to comment Share on other sites More sharing options...
fredogauvino Posted July 8, 2015 Author Share Posted July 8, 2015 G-Spot, Silicone, wet bike, this thread is not going where I thought it would... I should never have use form foam that is normally used for bras... This bag is purse... I meant cursed... Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted July 28, 2015 Premium Member Share Posted July 28, 2015 Great work! Very impressive. What is next? Custom made lower bodywork? A skid plate perhaps? Cheers 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
