vango Posted April 7, 2016 Share Posted April 7, 2016 I fill my bike full and after about 10km it drops to half tank then randomly it jumps to full and then randomly back to half. Any ideas what could cause this ? Link to comment Share on other sites More sharing options...
skipperT Posted April 7, 2016 Share Posted April 7, 2016 Sounds like the sending unit is sticking, or its not plugged in securely. Does the bike run ok? No hiccups? Skip Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted April 7, 2016 Premium Member Share Posted April 7, 2016 Sounds like the sending unit is sticking, or its not plugged in securely... Before I dive in....would you know whereabouts of that connection (under tank)? From the cruise control install instructions: A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
vango Posted April 7, 2016 Author Share Posted April 7, 2016 My bike runs fine. It started after being stored all winter. I'll check the connection. Thanks Link to comment Share on other sites More sharing options...
wiggin Posted April 7, 2016 Share Posted April 7, 2016 I fill my bike full and after about 10km it drops to half tank then randomly it jumps to full and then randomly back to half. Any ideas what could cause this ? Same thing here, just noticed that yesterday.... Link to comment Share on other sites More sharing options...
vango Posted May 15, 2016 Author Share Posted May 15, 2016 Ya mine definitely doesn't work at the top end at all. It never shows a full tank . Its stuck at half tank. If it does show full , it usually blips back to a half a tank after a few seconds. It still works as I run down on fuel it goes down , but irritating. I pulled the tank. Checked the connection. Seemed fine. Any ideas ? Link to comment Share on other sites More sharing options...
skipperT Posted May 15, 2016 Share Posted May 15, 2016 Only thing you can do from here is tear into it. Remove the tank, drain it, flip it upside down, remove the fuel pump assy and test the sending unit. To test the sending unit you move the arm gently through its full range, monitoring the resistance measurements. Specs are in the service manual. If it's in the full position and the resistance is way off, you are looking at a new fuel pump assy and gasket. The only other wrinkle here, is that if there is too much resistance in the wiring between the sending unit and the Instrument Cluster - then the sending unit is fine and you have a bad/dirty connection somewhere. My guess is the sending unit has either failed when full, or its sticking for some reason. Skip Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted September 27, 2016 Premium Member Share Posted September 27, 2016 My new in July 2016 Red 2015 FJ-09 averages about 41 ~ 43 mpg on our crappy 91 octane E10 fuel and the gas gauge was fairly accurate and ran down normally until recently (at about 5,300 miles) when it started sticking on full until about 105 miles then suddenly dropping to half full where it should be approximately. This has occurred over the last 4 or so fill ups except for one when I filled up and the gauge was stuck at about half way then suddenly went to full and then did the usual stick until 105 miles thing. Weird. I've run as far as 21 miles on the blinking empty light count-down and get about 2 mpg less than the mpg indicated. Link to comment Share on other sites More sharing options...
norcal616 Posted September 27, 2016 Share Posted September 27, 2016 My fz-07 does the same thing in the summer time reads a bar higher in sunlight and 1 bar less in cool weather...still get very similar total miles per tank...I go by mileage rather than rely on the fuel gauge...it's just a quick reference for me...gauges can be off as much as 10% from factory... 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted September 27, 2016 Premium Member Share Posted September 27, 2016 @2and3cylinders - this is normal behavior for the gauge. Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted September 27, 2016 Premium Member Share Posted September 27, 2016 It is normal to show half after fill up and then jump up to full 5 miles later? Link to comment Share on other sites More sharing options...
Premium Member martyl Posted September 27, 2016 Premium Member Share Posted September 27, 2016 It is normal to show half after fill up and then jump up to full 5 miles later? Not that's not normal. Mine will reset to full right as I'm pulling out of the gas station. To jump to half after around 100 miles is. There is no three quarter full mark which I don't like but then again I go by math and my trip meter on all my motorcycles. A Motorcyclist's Church is the open road.... Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted September 27, 2016 Premium Member Share Posted September 27, 2016 when it started sticking on full until about 105 miles then suddenly dropping to half full where it should be approximately. Yes this is normal for the bike. Sucks, but lots of us have it. I filled up and the gauge was stuck at about half way then suddenly went to full and then did the usual stick until 105 miles thing My experience - if mine sits on a sidestand overnight, it will sometimes show a lower bar reading then jump up after several miles. The bike isn't just filled up but it's dozens of miles above the lower bar. ...get about 2 mpg less than the mpg indicated. Mileage reading is about 5% optimistic. Sounds consistent with others reports. These AREN'T as accurate as car fuel gauges (not that those are particularly accurate). Link to comment Share on other sites More sharing options...
